Corrext, PCM Relay Control (RC) provides ground to the relay, energizing D5 pin.
You should look into Foscan. There must be codes in the pcm.
C is connector id, the number after is the pin number in that connector.
C175b is one of the pcm plugs.
C1035's are the underhood fuse block/BEC connectors
