GlassTop09
Thanks for posting the link to OZGaugePods................I'm gonna get the 05-09 S197 steering column upper gauge pod for my Stang soon so that I can finally install my Zietronics ZT-4 Dual Wideband Controller I've had in storage for the last 7 yrs.............I like how this pod integrates w\ the interior of my Stang (charcoal black thus should be a good match) ..........so I can finally get my wideband O2's permanently installed\set up w\ my HPTuners MPVI2+ interface for future datalogging\tuning purposes.Been a busy couple months, but getting back into this again. It was a tough decision but I'm going to go for a centrifugal s/c. Jumping back to the topic about the CMCV's, I talked to the shop about it, and they're not really worried about the opening schedule since the boost doesn't come in until 3K when the valves are wide open anyway.
We also spent some time looking into flex fuel controllers (would detect the ethanol content and respond accordinlgy) -- but it turned out that all it would do is up the fuel rate on this generation of car. It's apparently only on the '15 and up where it could integrate with the ECU to adjust the timing too for more power.
Also putting together a set of gauges I'm going to put in the car. Want to keep the look consistent w/ the interior, so looking at Sport-Comp gauges.
Oil pressure:
https://www.autometer.com/2-1-16-oil-pressure-w-peak-warn-0-100-psi-stepper-motor-sport-comp.html
Coolant temperature -- my shop is advocating for this one, but I've got to ask them why. The gauge in the IUP cluster isn't an idiot gauge as far as I know. But if they have a good reason:
https://www.autometer.com/2-1-16-wa...-warn-100-260-f-stepper-motor-sport-comp.html
Boost/Vaccuum: (yes not necessary but fun is the name of the game here)
https://www.autometer.com/2-boost-vac-30-in-hg-15-psi-fse-sport-comp.html
Wideband Air/Fuel:
(analog version): https://www.autometer.com/2-1-16-analog-wideband-fse-sport-comp.html
(digital - probably the better one to have): https://www.autometer.com/2-1-16-wideband-a-f-w-sensor-fse-sport-comp.html
Also looking at places to mount them. First and foremost is the Saleen gauge pod. Been a big fan ever since the S-281 came out
Might also do a vent gauge next to the door
and if I end up doing all 4 gauges, I was thinking about putting it on the steering column. Seemed like it'd have to be a fabrication job, but I found this one online:
https://www.ozgaugepods.com/product-page/2005-09-ford-mustang-column-upper-trim-gauge-pod.
