the sandman
I have a 07 GT that has a definite miss at Cruise speeds and below. No codes are showing up. What should I look for? Thanks
Actually a scanner with Mode 6 capabilities should show these events if it is truley a misfire. Is the car in question an Auto or Manual?Is this a new issue? Could be bad gasoline?
Connect a scanner with datalog capabilities and drive it to record the event.
i wanted to say, im pretty sure it will fix it.if i were you id get it fixed by replacing all the cop with ford ones , (unless you have a good coil tester. but they are prolly starting to go out )
and replace all the spark plugs,
that will give you the best choice for success ,and if it still does it (which im pretty sure it will),
you will be alot better off trouble shooting
yea ive heard people changing the ecu and still having problems,A couple years ago, I thought I had a small occasional, intermittent miss. No CEL and no codes. Changed the plugs, but still had this vague unsettling problem. No CEL/codes. Tried fuel injector cleaner. Even changed the coils, but still not change and no codes. About a week later the CEL came on with a code for a misfire. The fuel injectors were clearly working normally, so I took it to a shop. Their analyzer said it was my PCM. Took almost two weeks to get a new computer, but it definitely fixed the problem. No problems since.
I still think I did the right thing by trying the simple, cheap things first.
Michigan definitely gets cold in the winter. Very humid here too b/c it's just two peninsulas.***
i think ecu go bad on these cars when you live in cold climate , or its in bad weather all the time,
i dont think they just go bad just because ,, its due to corrosion in the breadboards and shorting out the little capacitors and such
The plot thickens.Got one A arm and tierod end on, doing otherside today. I drove car yesterday and it threw 4 codes p0132 o2 sensor circuit high voltage bank 1 sensor 1, po153 o2 sensor circuit slow response bank 2 sensor 1, po420 catalyst system efficiency below threshold bank1, po430 catalyst system efficiency below threshold bank 2. So what do they mean? Car has Accel coils. Probably put in when cams were installed. Unknown age.
