for those of you with lightweight batteries...
Kaldar142
Silver Spring, MD
Well, i got myself a super lightweight small battery (8lbs) and i was wondering how you guys mounted yours?
i left mine upfront where the original battery was... took out the battery tray and did a little redneck engineering... lol
took the stock battery tie down strap and cut it to fit my new battery, used a self tapping screw and tightened it down. i also put doubled sided tape on the bottom of the battery to help it stay there (LOL)
how did you guys mount it? i dont know if this will be my permanent solution, but i went out and took a bunch of hard turns and it doesnt budge...
-Joe
Update:
Made my own battery tray for it;
Matt D
S197 Pilot
Toronto,Canada
That's how mine is mounted too lmao I have to move it to the back when I get time
I just put some double sided tape underneath just to keep it secure
94tbird
4R70W FTMFW
looks like my waverunner batter haha
Personally i see no reason to go to a lightweight battery. Unlike the foxesand new edge cars, the battery is not sitting in front of the front tires on the front end. It is in a semi neutral position back on the firewall and behind the front wheels.
GIG4FUN
Rock 'n' Roll Moderator
Iowa
I used the same velcro I use on my stomp boxes on the pedal board... (guitar player talk...)
:rockon::whistling:
Kaldar142
Silver Spring, MD
so theres no point in losing 25lbs off the front end...?
Kaldar142
Silver Spring, MD
What battery is it?
DEKA EXT14
its the same thing Braille uses, except its not overpriced.
SO, i don't know if this is battery related or not... but i had it disconnected for a while (obviously) but when i'm driving and i clutch in, the RPMs dip to about 500, rise to 650 dip to 500 then go back to around 750... ???
GIG4FUN
Iowa
ouchie!
word, I hear ya
who cares if you have to hoof it.. just hope it's not raining too heavy and too far from home.
Kaldar142
Silver Spring, MD
i did tons of research before buying the battery, so hopefully it will last... if not it was only $60.
by the way 94tbird, i hear you on the battery location... its in an awesome place stock... but come on $60 for 25lbs? seems like a good deal to me, especially when its the SAME exact battery braille advertises as their lightweight car batteries
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I might do something like that just for the track. Then put my Optima back in for daily driving. But either way, I want it in the trunk.
94tbird
4R70W FTMFW
Its behind the front wheel, so technically it is neu tral weight. Consider it 25 lbs to balance the pass side vs your weight in thedrivers side
don_w
San Diego, CA
With all due respect, that's hogwash. It is still in front of the center of gravity, so it's not "neutral". Losing weight anywhere is a good thing. And if you can't lose it, then shifting it to the rear is better than having it in front of the firewall.
