Matt D
S197 Pilot
good job catching that, keep us posted
dropped off the lifters at my buddy's CNC place to be redesigned so they actually work. should have them back this week and then i get to spend an entire day adjusting my valves again.Oh no!!! This sucks man, I hope you can get the motor done soon, I want to see what power this thing makes!
Good luck, I hope this thing makes over 430rwhp.dropped off the lifters at my buddy's CNC place to be redesigned so they actually work. should have them back this week and then i get to spend an entire day adjusting my valves again.
anyone thinking of switching to a solid lash adjuster (lifter) i would strongly suggest using a solid version that has shims.
I'm also going to disassemble a stock hydraulic lifter and see how they are designed to see if there is someway of re-engineering them. it would be great if there was a limited travel anti-pump up lifter available for these engines. then you could run crazy cams\lots of spring pressure and not have to worry about valve float at high rpms.
one thing i found during my measurements with this problem is that i had no where near the valve lift i was supposed to and this thing still ran really good. i had lost about .040" lift which i will regain once this is fixed. that should be worth some extra power![]()
JJ it's coming to you this weekThis car is no joke fella's. If Ron doesnt post a video of how it sounds I will. It is flat out bad ass and revs up so quick that it feels like it on nitrous all the time.
I have the pleasure of tuning it and so far so good. There has been alot of interest in E85 tuning and I do quite a few Lightnings that run the fuel. The only thing you have to make sure of is that your anything metal that the fuel touches has the proper coating on it so the E85 doesnt eat it up.
I look forward to Ron getting it all fixed up and back here for some serious dyno time but what I really look forward to is when it hits the track.
JJ@WMS
only reason i went with these is because they said they were adjustable in the engine.....lie. no way. i had to do the same thing and honestly it would have been easier with shims since they had to come out about three times for each follower:Jesel is your friend. About as high dollar as a D.C. hooker but they are your friend.
Just waiting on JJ for my dyno time. one thing i did get was an e-85 fuel checker from Quick Fuel Technologies.Any updates?
Thanks.
I know when JJ set it up a few weeks ago he had some trouble using stoich @ 9.85 so he started playing with stuff and it seemed to run better at around 11 or 12 (whatever stoich is for e70) which lead him to think my fuel was a bit off on the mixture. i can't tell using my gauge cause my wideband is setup for gas so it still sees 14.7 as stoich. I'm running 12.2 at wot using my wideband but i can tell it's lean just from all my experience with running alcohol motors. a lean alky motor has a fluttery sound. also the way it idles plus a hesitation and it heats up fast at wot then cools down at an idle.How lean is it running? Are you measuring in terms of Lambda, or is the stoich. point of the gauge set to 14.7 or 9.85?
yep. that will fixed as of tomorrow. dyno at 10am.You can read the AFR just fine with a gas calibrated wideband gauge. Stoich for E70 is about 10.7 All wide bands read in terms of lambda and mulitply that times whatever the stoich is set at for the gauge to display anyway. 12.2 shouldn't really be lean. that would be .83 lambda or 8.17 in E85 terms. 12.3-12.5 is where I found my stock motor made the best power on E85 when read on a gas cal'd wideband gauge.
I'm really looking forward to the results. I know it must be killing you not to be able to really romp on it yet.
