Vacuum Pump installed
andyman
what a mess...
tampa
Since the cams were put in, the car would idle at ~10" (according to the gauge) and that number would sometimes go to 5" or less depending on how hot the engine is and whether or not the heat/air was on. A few times i've almost rolled into traffic with the brakes all the way down and the car still moving!!!
First tried using a vacuum canister, but that didn't help at idle at all so I got a vacuum pump from Comp Cams through Jegs http://www.jegs.com/i/Comp-Cams/249/5500/10002/-1&parentProductId=945586
Just put it in and it does make some noise but it's not bad especially since you can barely hear it over the car itself lol...
Still getting ~10" of vac on the gauge with the manifold vacuum line plugged off. The pump works off a relay, and is wired into an add-a-fuse in the passenger kick panel. The pump itself is mounted on the firewall next to the battery, I'll have pictures tomorrow... racing 1/4 mile tonight!!!!!!!! The air is cool, it's going to be faaaast. It's good to have solid brakes again.
edit: here's pictures
The kit came with rubber mounts, but that made it stick out too far and rest on the fuel rail.
tmcolegr
It's All About the Build
Central, FL
Not to get off topic, but that is the exact reason I went with the VSR Stage 2 cams rather than the SPR Stage 2 cams. When I spoke to Comp Cams prior to puchasing my cams, they warned me about the potential for poor idle quality/low vacuum/braking performance issues with the SPR Stage 2 cams. For a daily driver, they suggested the VSR Stage 2 or SPR Stage 1 to prevent those problems.
andyman
what a mess...
tampa
ahh good to know...
The only things left to do with the pump is install an 'oh shit' master switch in case the relay fails I'll flip a switch and turn on the pump, and maybe mount a vac only gauge on the firewall cover for monitoring.
JeremyH
3V Fuel Guru
Virginia Beach
I am looking into this when i get the car back with the cams. Altough i have a manual so dont really have to worry about the car rolling out at a stop. But might just do a vacuum canister and not a pump.
spyder7724
Maryland
yep i've been having the same issue. i did order a new vacuum canister in hopes that it will help. i was pretty sure i was going to have to install a pump as well. gotta try the can first before i spend $300 though.
andyman
what a mess...
tampa
If you want strong brakes at idle, the can won't cut it unfortunately.
09Stroker
Just curious but what about using a vacuum pump off a Ford diesel pickup? I ask because I will be in the same boat with my Livernois Stage 3 blower cams(same as comp stage 2) and I am going for more of a "stock" look.
andyman
what a mess...
tampa
Depends... what activates it? This comp pump came with a vacuum switch that turns on the pump when the vac drops below 18" and then shuts it off when it gets to 22".
Personally I think the comp pump is very camoflauged.... I'm not trying to be a spokesman for comp though :)
09Stroker
Same concept, 12volt motor just need the vacuum switch to turn the motor on and off which can be found easily enough unless there is something odd in the wiring that I am missing
94tbird
4R70W FTMFW
vacuum can works perfectly for my car wit hthe BBR stage 2 cams. Without it i had no brakes. With it, they are perfect. not sure why it wassnt working for you
andyman
what a mess...
tampa
Braking at idle (traffic kind of stuff) didn't change for me, that's what I was looking to fix.
94tbird
4R70W FTMFW
thats exactly what it fixed on mine? Did you have it plumbed backwards maybe?
GhostPsalm
Houston
Can you guys post up pics of your vacuum canister and hose routing? i got the 5200 from comp cams and the fittings it came with are two diff sizes, that's throwing me off
