Sway Bar Bushing Question
Mustang30212
Columbus, Ga.
I am installing a set of front and rear sway bars from an 09 Shelby on my 05GT. Are the factory Shelby bushings any different than the GT bushings?
Who sells a good aftermarket set of bushings?
RH
me32
Nor Cal
RH
im not sure if they are different or not. but if your just upgrading the bushings then go with that energy suspension polly bushings. unless your upgrading to the GT500 front an rear sway bars. i do know for sure that the KR bushings our better than the GT500 stock ones.
JSauers
Yes most aftermarket bushing are a solid neoprene type bushing. The factory are a hard rubber. The ride is stiffer with the neoprene bushing, but it will corner flatter. Make sure you use the proper lube with the neoprene.
