What Is Your Full Rear Suspension Set Up?
Nickoli
Farmington MO
BMR Race Adjustable Upper Control Arm
BMR Race Adjustable Lower Control Arms
Steeda Sway bar
Steeda Adjustable Panhard Bar
Panhard Brace
Steeda Ultralite Springs
Stock Shocks
Steeda upper rearend housing spherical bushing
doogie
SE WI
I was actually considering the single adjustable QA1's and this reply from JDM made me change my mind to Koni's (mainly the comment about cold as I live in WI). http://s197forum.com/forum/showpost.php?p=375298&postcount=29
Then I happen to find a killer deal on some barely used Koni Sport rears for $200 shipped!
I have the following thus far and will know in the spring if any more changes are needed when I hit the track for the first time:
Steeda adj panhard bar
CJ springs (rears installed)
Steeda billet poly/poly LCA
CHE LCA brackets
Hawgman
THE fucking bad guy
BMR non adjustable lower control arms
BMR LCA relocation brackets
CHE rear axle brace
Syophon Performance rear sway bar and end links
Ford Cobra Jet springs
Edelbrock adjustable upper control arm
BMR adjustable panhard bar
BMR panhard bar brace
alloy6ix
Wiener Dog Racer
Big ass state shaped like Texas
CHE LCA brackets
Wow, nice! Where'd you find them at that price??
DownriverT
downriver MI
BMR adjustable uca
BMR lca
BMR sway bar
CHE upper and lower ca brackets
CHE panhard bar and brace
Shaftmasters alum ds
LPW girdle
Finishing the rear suspension this year with
QA1 shocks
che axle brace
Chris07GT
Tampa, FL
BMR LCA's w/polyurethane and speherical bearings
BMR UCA's
BMR UCA Mounts
BMR Adj Panhard Bar
BMR Rear Sway Bar
Eibach Pro-Kit springs
BMR Driveshaft Loop
Steeda Aluminum Driveshaft
BMR 1/2" Lowered Tubular K-Member
BMR Front Sway Bar
All purchased locally directly thru BMR and Pro-Fab Performance, both of which are about 15 minutes from my house
Also installed the Panhard Support Brace soon as well as the Ford Racing Axle Girdle
Some pics of the set-up:
MLC40
Naperville, IL
Nice setup but I didn't you should lift the car by the k-member mounts. Any issues with lifting there?
BMR UCA's
BMR UCA Mounts
BMR Adj Panhard Bar
BMR Rear Sway Bar
BMR Driveshaft Loop
BMR Front Sway Bar
uniquestang
Leander, TX
cobra jet springs
bmr solid lca
bmr adj uca
qa1 single adj shocks
spohn hd sway bar
also have the spydershaft and bmr boxed subframe connectors
alloy6ix
Wiener Dog Racer
Chris, great set up!!! And looks much better with the painted axle tubes. I just finished doing that to mine a few hours ago. :thumb2:
If I don't get a PM back by tomorrow on some Metco stuff, I'm just going with the BMR pieces. Seems to work for quite a few of you guys! :thanks1:
Keep the list going guys!!!! :beerchug2:
don_w
Dyno Numbers - Who Cares?
San Diego, CA
BMR Adjustable Lower Control Arms
BMR Adjustable Panhard Rod
BMR Panhard Relocation Bracket
BMR Adjustable Upper Control Arm
BMR Extreme Anti-Roll Bar
Steeda Lower Control Arm Relocation Brackets
Spohn Rear UCA Housing Bushing Kit
Rancho Adjustable Shocks
Cobra Jet Springs
69Mach1-409
South Jersey
I have the full CHE setup on her now:
- Adj LCAs (Poly/Delrin on both ends)
- Adj UCA (Poly/Delrin on both ends)
- HD UCA Mount
- Adj PanHard Bar (Poly/Delrin on both ends)
- HD PanHard Bar Brace
- I also have the CHE A-arm brace w/ Trq Limiters, BMR Frt DS loop, and Coast 1pcs Alum DS.
I have the CHE drop bracktes (anti-squat) on the work bench, but I'm not sure I'm going to install them. I'm not lowered and she's always hooked fine at the track..
alloy6ix
Wiener Dog Racer
Alright what It looks like is the Steeda street and race LCAs for me along with the Steeda relocation brackets. Now to get that Adj UCA.. I'm getting adj everything because I have a spydershaft on the way and I'm gonna have half a heart attack if I start getting heavy vibration from that thing.
Matt D
S197 Pilot
Toronto,Canada
Call up Jeremy at upr. Tell him Matt Da Silva sent you and you need some suspension parts. He will hook you up man
