06gtmustang
It would be awesome if you could post up the exact weight difference between both fans. My car is on the diet stage still
What did you have to do electrically to get the fan running? Just wires?
FYI: Air flow should go from the front of the car to the rear. Unless you plan on backing up everywhere you go.
FYI: You just lost a LOT of cooling capacity at low speed. Even if that fan moves as much air as the stock fan, it is only cooling a small part of the radiator. There is a reason that the factories spend the size/weight/cost and put a shroud on the cooling fan.
Matt, if your going to make one, you might as well make one for me too! Hell, make a whole bunch and make some money..?
I never thought about doing a slim fan.. until I saw this thread. If it drops more then 5 lbs im game
