My long awaited build... (I don't think 56k exist anymore) So lots of pics...
Boozshey
Tampa
So as much know I have been stock piling parts while I was deployed. Well here's the list and the start of the build...
I will try and continue to take pictures as I go along. Not all parts are pictured as I may have forgotten or have not made it through the mail yet.
Engine
-Saleen Supercharger
-Supershaker Conversion
-AFCO Heat Exchanger
-BGG 8-Rib kit with 3.2" Pulley
-Moroso Intercooler Battery location tank
-2 - Moroso breather cans
-Comp Mutha Thumper Cams 127020
-Comp Phase Limiters
-1 Step Colder Plugs
Fuel
-Aeromotive Fuel Rails
-Misc hoses and fittings for fuel rails
-#60 Injectors
-GT500 Fuel Pump
Transmission
-Spec 3+ Clutch
-Fidoza Flywheel
-CHE K-Member Brace with torque limiter
Brakes
-BAER Decelerator rotors for all four wheels
-HAWK HPS Pads
Suspension
-BMR LCA Relocation Brackets
-BMR LCA
-BMR Adjustable UCA
-BMR Adjustable Panhard Bar
Looks
-SHR Black Fuel Door
-Black Upper/Lower Billet Grille (Pony Delete)
-1969 Grille Emlbem (Not Remake)
-CDC Aggressive Chin
-Open headlight bucket mod
-Powder coated cam covers <- will send away as soon as I get home
Interior
-White face gauge overlay
-MyColor Cluster
-LED's for interior color change
-Autometer Dash Gauge Pods
-SOS 3 Pillar Pod w/shift light mount
-Raptor shift light
-5 - Phantom II gauges; boost, fuel pressure, oil pressure, oil temp, water temp.
-AEM Wideband Air/Fuel
Exhaust
-Kooks Headers
-Kooks Catted X
-Stage 8 locking header bolts
Misc
-JDM Tune
-SCT 3
-Trunk mounted battery box
-Poly Motormounts
-Canton Power Steering tank
-Supplies to move all wiring out of engine bay
-Move PCM and Fuse box to glove box
Boozshey
Tampa
HERE COMES THE PICS....
Engine
Fuel
Transmission
Brakes
-HAWK HPS Pads
Looks
Interior
-MyColor Cluster
-Raptor shift light
Boozshey
Tampa
Exhaust
-Kooks Headers
-Kooks Catted X
Misc
-JDM Tune
-SCT 3
-Poly Motormounts
-Canton Power Steering tank <-still gotta buy
MISC Parts and Supplies...
Boozshey
Tampa
So yesterday I spent the day taking a lot of stuff apart. There was a problem with the original blower I bought so I had to wait to find another. JDM has sense shipped out the new blower and should be here in the next week. So in the mean time I prepped everything and did other things that would be needed.
I started the day off by removing the CDC Shaker and CAI. I had presold those items and the buyer was coming by to get them. Once that business was taken care of I then made the goal to get the CAMS and phase limiters installed.
Everything went pretty straight forward and was not as hard as expected. Just take your time if you have never done it before and it will all make sense once you get in there.
Here are some pics of the progress. This not a DIY thread nor was I going to make one. There are plenty out there that are helpful and a waste of my time to mimic just another. But if you have questions about anything along the way please feel free to ask.
I found that by cutting a hole in the hood allowed me to hook a light up. Seemed more practical to cut a hole than to take off the hood.
Alot of wires disconnected and fuel line removed.
I removed the intake now because it allowed more room for the cam install and since it will come off for the Saleen Blower then why not now...
Removed Cam Covers.
I tried to use the compressor tool but it wouldn't compress the springs far enough and I got mad so I didn't use it. I just back the bearing caps off slowly like half the other guys.
Bearing caps off.
Phaser and Sprocket removed awaiting the COMP Phase limiters.
New Mutha Thumpers installed...
Temp cam covers... just to keep dirt out.
tmcolegr
It's All About the Build
Central, FL
I have never installed a Saleen S/C with a Super Shaker. Does the Super Shaker still require the vacuum line upgrade kit or did Jim III already hook you up with that? Why did you choose the Comp Mutha Thumper Cams 127020 - just asking? What gear/tire diameter combination are you planning on using? Did your pulley kit include a V10 diameter water pump pulley to improve belt wrap on the S/C? What gaskets are you planning on using with your headers? The gaskets supplied by Kooks will fail. Most usually use new OEM gaskets.
PS: I'm in Lakeland so if you have any questions PM me with your info
usafimj
Damn dude. Its going to be an awesome ride. Why didn't you get ss brake lines?
Boozshey
Tampa
I have never installed a Saleen with a Super Shaker. Does the Super Shaker still require the vacuum line upgrade kit or did Jim III already hook you up with that? Why did you choose the Comp Mutha Thumper Cams 127020 - just asking? What gear/tire diameter combination are you planning on using?
JimIII did put on the kit before sending it out and knew I would be running a Supershaker conversion so I would guess yes.
I chose the mutha thumpers for sound. (Yes I am man enough to say that's why I got them) :)
I have 4:10 gears, and tires are 255/45 and 285/40.
Boozshey
Tampa
Still waiting to find a good deal on some used ones, if anything I will grab some Russell's right before the brake install.
tmcolegr
Central, FL
I edited my original post to include 2 more questions about the water pump pulley and header gaskets.
Boozshey
Tampa
Stock size pulley... I have a BGG Tensioner arm, I need to edit my post to include that. But the 8 Rib will take care of slip.
I plan on using the stock header gaskets.
tmcolegr
Central, FL
Does the BGG kit include a 90mm idler pulley at the location next to the P/S pump. This will improve belt wrap in the crankshaft pulley.
Not questioning any of your decisions but I have already been though just about every belt/pulley combination there is and just don't want you to have any of the headaches that I've already encountered.
Boozshey
Tampa
Not sure, but I do know that the 8 rib kit alone will eliminate the belt slip...
tmcolegr
Central, FL
I also see your using Prothane mounts. Those look like the std. height mounts. Does the Saleen S/C w/Super Shaker require the "lowered" Prothane mounts?
Boozshey
Tampa
No the lower mounts would be bad. It would cause the scoop to sit to low in the hood.
