does any1 drive their jegs wheels on the road? it says not for street use?
325 m&h just fit on 15x10 racestar'tread is just inside fender
did you have to cut that useless bracket off inside the wheel well. i did my relocation today, i just dont have the heart to cut that bracket if i dont have to.
I had to cut mine off. You just need to cut the bottom 1" or so off it, the little tab is all. I have the Racestar rims also.
I use the rear spacer as well for extra saftey. When i was looking into 15" wheels i tlaked to chad05gt and he uses the jegs as well. We were tlaking about how something happend to his rear once with the wheels and he wish he had a spacer on.
Has any1 noticed the hole for the conical lugnuts to screw into are rather small? I had a bad problem at the track one day where it looked like my wheel shifted or wasnt put on straight. I had to bang a socket in to get the lugs off. What do you guys tourqe your lugnuts to on the Jegs Wheels? i did mine to 110ft lbs.
