Combined 15" wheel Fitment Thread
CJGT
schoharie,ny.
325 m&h just fit on 15x10 racestar'tread is just inside fender
RedFire07GT
11sec N/A 3V
Ocean County, NJ
Quote:
Originally Posted by Freaknazty
  • JEGS SPORT STAR CAST WHEELS
    Front : 15x4 W/ 1.75 BS , PN: 555-67051 , 3/8" Spacer ,PN: 555-65051
    Rear : 15x8 W/ 5.5 BS , PN: 555-67077 ,NO Spacers , NO Relocated Swaybar , both front and rear use factory length studs and stock conical style lugnuts
im running the jegs 15x8 with a MT ET street DR and the MT Sportsman S/R up front. There alot lighter then my stokc fanblade wheels.
k_aimone
did you have to cut that useless bracket off inside the wheel well. i did my relocation today, i just dont have the heart to cut that bracket if i dont have to.
N
navbtcret
Guest
I had to cut mine off. You just need to cut the bottom 1" or so off it, the little tab is all. I have the Racestar rims also.
h8imports
does any1 drive their jegs wheels on the road? it says not for street use?
I did also. I think the not for street use is because the front are 4" wide. They don't want anybody to wreck because the tires are so small. Don't hit corners fast and you will be fine. I had the Weld draglights on my old coupe and I drove it every day with the 3.5 up front and it done fine!
CJGT
schoharie,ny.
the only thing i cut was the piece that hangs down where sway bar was bolted.every thing else cleared the wheel & tire
h8imports
My Jegs wheels are 8's in the rear but mine didn't hit anything. I think ya'll are talking about the race stars but I just wanted to let everyone know the Jegs 8's didn't hit on the rear of my car.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
I still use a spacer on the rear with my 15x8s jsut for saftey i guess.. Its not a must the whel will fit fine without it.
Has any1 noticed the hole for the conical lugnuts to screw into are rather small? I had a bad problem at the track one day where it looked like my wheel shifted or wasnt put on straight. I had to bang a socket in to get the lugs off. What do you guys tourqe your lugnuts to on the Jegs Wheels? i did mine to 110ft lbs.
SlvrS197
Why use a spacer if its not needed? I dont see how that is safer...just less stud to screw onto if your using the stock studs
SlvrS197
has anyone on here tryed the jegs sportlite(draglite) rears at 15x8?? did they fit up lite the sport stars?
RedFire07GT
11sec N/A 3V
Ocean County, NJ
I use the rear spacer as well for extra saftey. When i was looking into 15" wheels i tlaked to chad05gt and he uses the jegs as well. We were tlaking about how something happend to his rear once with the wheels and he wish he had a spacer on.
h8imports
I see no reason to use a spacer unless the wheel hits the caliper. If you hear it hit then get the grinder out and grind some. Other than that I see no reason to use a spacer. If it clears and don't hit the caliper I wouldn't use the spacer. To me thats more of a chance to break off lug studs. Like SlvrS197 said I don't see it being safer.
h8imports
Yes I have thats why I have bought 1/2x20 lug nuts with a 3/4 head on it. They fit fine. I bought them from my local tire shop for 1.00 each. If you can find any let me know and I will give you there number so you can call them. I'm sure they can ship them to you. If not I can.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
youll have to see if Chad05gt chimes in here soon and explains why he suggested to run a spacer for the rears. Im sorry i forgot the issue he ran into but i wish i rememberd. It was so long ago. Ill see if i cna bring the old PM up to let u guys see where im comign from. Im sorry for the confusion.
