Got the catch cans today and had a strong oder of fuel. So much for no leaks. Had 3 small leaks in the fuel lines. Bought some o-rings today, I hope that will solve the problem. Replaced the fuel filter real quick before work. Hope to seal the leak, mount the catch cans and do the headers tomorrow...
This is the Water Temp sending unit...
i like the wrinkle on the covers,who did them and how much was it,ive been debating on doing mine.
Looking bitchin'!
Rotors like that is what I want to go with the next time I need brakes.
Where was that located? I just bought a temp gauge today and was gonna put it in but it got dark out. Also was it a stock place you put it in or did you have to drill it? Any help would be greatly appreciated!
It's Autometer Part# 2268, it's a pre-drilled plug on the driver side towards the rear. You can access it from under the car. Just have a bucket ready cause you will lose alot of fluid when you take it off.
Also here's from autometer...
Water Temp Location and/or Thread Size
for 4.6 engine(s)
Look below the last freeze plug on drivers side (left side) of the block. There will be a threaded in plug (16mm x 1.5). This can be accessed and removed from under the vehicle. For electric gauges use an Auto Meter model #2268 adapter. For mechanical gauges use an Auto Meter #2275 adapter.
