Status
Not open for further replies.
psfracer
billy badass
Valencia, CA
Nice, and that was on the turbo only correct? Man, if you squeezed out of the hole, that is an easy 9 second pass.
TurboPete
Miami, Fl
Yeah Boost only , didn't spray it because it was shutting off on me on the shifts. Got that figured out already so will be going back soon . Might change the gear to a 3.27 and head back to try again.
Pete
jroc07gt
its orange not yellow!!
hammond,la
R/T ... .455
60' ... 1.831
330 ... 5.316
1/8 ... 8.152
MPH ... 86.89
1000 ... 10.617
1/4 ... 12.673
MPH ... 112.12
R/T ... .619
60' ... 1.871
330 ... 5.389
1/8 ... 8.242
MPH ... 86.53
1000 ... 10.698
1/4 ... 12.748
MPH ... 112.41
Mods in sig. Nitto NT555R @ 23PSI
Boss281
New Windsor, MD
Looking at the N/A list, in terms of record holders, shouldn't Qwikhuh line#7 be a record holder with stock heads/stock cams? Seems to me he mentioned being stock "throttlebody to oil pan"...
Just a thought...
confuzed
Just a thought...
i do agree, it would be nice to have a stock internals "list" like the ls1 guys do. (i used to be one!)
no cams, headwork, big bored/stock heads......STOCK motor. tb and deletes would be ok, but thats it. :hi:
Boss281
New Windsor, MD
Wasn't Ron Leonards car totally stock block?
Crap, you're right. His "stock block" record was removed from the list when he dropped a new record with his built 5.4l. Don/Paul, I think we may need to add Ron Leonard's 4.6l record back in, as that bit of history is lost to us in the current sheet....what think?
pacettr
PJ Lover
Yukon, OK
+1...
Dr Wu
Faraway
Abstract Zone
Here's my slow best to date:
2010 GT Deluxe Automatic with no options. No spare tire and a 1/4 tank as far as weight savings go.
Mods: K&N drop-in filter, AE aluminum drive shaft, 275/40/17 M/T, BBR 93 race tune, Steeda UDP & ECMP's, 3:73's.
Long way to go...
It's car #1961.
confuzed
new best! added imrc deletes and finally REALLY hooked!! GEARS CHANGED TO 4.10S
12.27 @ 109.95
Five Oh Brian
Mustang Guru
Not my best runs ever, but the best day I had a back up run to count for the list here....
2007 Mustang GT Coupe...
  • 281 CI (4.6L 3V). Completely stock, except the blower (see below).
  • 5R55S Automatic Trans, completely stock except for the converter (Fuddle Racing 3600 rpm stall converter).
  • Vortech V2 S-trim - standard (non-intercooled).
  • 10.5 psi boost at 6,400 rpm shift points.
  • 4.10 FRPP gears in an otherwise completely stock 8.8" rear end.
  • 275/40/17 BFG Drag Radials.
  • Race Weight = 3,650 lbs (includes me).
I'm car #4164 in the right lane for both passes (Pacific Raceway near Seattle, WA)...
1fastpony
I was scratching my head and wondering what time system NPR used. I have ran quicker times at a Accutime track but faster mph at a compulink. Don't know if one timing system favors time or et just an observation. I can tell you one thing though, that convertor damn sure locked up on the 1/8 mile.
psfracer
billy badass
Valencia, CA
Ok, I will be updating the timeslip sheets tomorrow morning ---- last chance for everyone to post up some time slips.....
Status
