rford426
Resident 5.0 H8R
Im getting alot of questions anwered here...When do you think she will be done and tuned up? Not to rush you or anything lol but jw where your at. Regardless its gonna be sick and can't wait keep it up!
Very good point! the rpms are gonna be moving faster for sure. And im sure i will have to dial it in again. Although i dont think im going to rev as high once the turbo is in.
What do you turbo guys rev to? stock/heads? cams/headwork?
rev limiter is set to 7k and shift light is 6400.
Tial website shows 6mm id line.With these tial bov/wastegate air line fittings, whats size silicon hose am i going to need, i believe its 10mm, not 100% on that though. Also heard that zipties arent gonna cut it so what kinda clamps should i use and where to get them, thanks.
http://www.tialmedia.com/documents/w3_tial_wginstall.pdf
Sweet build by the way. I'll be doing a sinlge turbo as well after I build my motor this summer.
Yea, it's inlet diameter. What size downpipe are you going with? I'm trying to decide between 3" or 3.5" for my setup. I want ~600 rwhp, so 3.5" may be better. Idk, I need to do some more researching to determine if 3.5" is necessary or not.Thanks! Im guessing thats the inside diameter of the tubing. I will probably just measure the air fitting barbs to see what size it is, 6mm does look to be right though.
You'll want that 3" downpipe, your gonna pushing some serious air lol.
