JeremyH
3V Fuel Guru
3.55 gears, this is just revving in neutral no clutch revving to 6k and held at 5K for 2-sec. eboost showed 1.2 lbs.
Willy ,how much boost will that wot box let u make and at what rpm.
Tony yeah i mean it is not bad a little more managable but once the boost hits in first gear when driving its hard to keep track and shift before it bounces of the rev limiter just due to the nature of where the boost hits and the rpms just shoot past 6K so fast. At around 5500-6000 rpm in 2nd and third it will start spinning the nitto street tires.
I can blow the tires off in 1st at any time and usually in second as well. Sometimes it will hook in second on good pavement and really hot out. When real cool out, I can get some rubber in 3rd.
