Twin Snail Build...
1BADHRSE
New York
Figured I would let you guys know, still pulling hard some 3,500 miles later running 12-13 psi with a/f ranging from 10.5-11.5.
I boost the hell out of her whenever driving...
Only issues I have encountered is:
In 75+ degree weather my temps will creep and my fuel gauge is still going wacky under half a tank...
I am going to buy a electric water pump and a 170 degree t stat if they sell them...
Boost > Sex
one eyed willy
Pizzle fo shizzle
Lakeland FL
Boost > Sex
do you already have a thicker radiator? thats what made the biggest difference for my car,cut my temps down by 10-15 degrees with the a/c on in 95+ heat!! and i bought a cheap one!!
Jaylee
Dirty South
Glad to hear everything is holding up well. I just started a thread asking questions about this kit and someone posted a link to your thread. After reading all 19 pages I have decided this is the way I want to go.
1BADHRSE
New York
I have a mishimoto radiator right now... When your temps were going up what was your stock cluster saying?? My moves a smidge.
12-13 psi? joe are you still on the stock bottom end?
Yes stock bottom end with hot rod cams on the heads...
Who tuned it??:beerdrink::popcorneat:
Stupid question you should get lashed... Chris btw
FYI, i saw this car last night. the system is sex
Thanks man that was fun as hell... I wish my car sounded like yours with the two turbos and blow off... The snails really quieted her down... You car makes me miss the obnoxious sound.. (^_^)
I would love to ride in that beast! Good work on putting together a nice setup!
Thanks man! She is a handful...
Yea the build was fun as hell! A tig is nessicary and you also can't be scared to drill holes lol!
one eyed willy
Pizzle fo shizzle
Lakeland FL
at 250-260 the temp gauge goes to red!! before the radiator swap i was running 200-210 driving around and 230 sitting in traffic.....that sometimes would spike up for a few minutes to 250 (happened only once).
new radiator in and im sitting around 190 driving and 210 with the a/c on in the traffic......its great!!
the other thing i did when i put the radiator in was re-wire my fans. i used to have the 2 fans running off the factory fan wires. now i have 12 gauge wire coming directly from the battery for each fan with a 30amp fuse for each fan......and 2 relays that still get triggered by the factory fan on/off wires. so each fan is getting its own 30 amp feed directly from the battery.
Boozshey
Tampa
Hey what do you know, I am doing that same thing right now in addition to running them to a switch for when the car is off also. :beer:
1BADHRSE
New York
I think I may have my aftermarket gauge in a hot spot then because when the after market autometer ford racing gauge goes to 250 degrees the stock temp gauge moves the slightest hair past the middle.. I have to data log and get the real numbers...
I am going to look into wiring my fans the same way you just said... I also have just 2 12"'slim lines I recall you saying you went to one 14" I may be wrong... Did you lower your t stat?
Driving my temps are around 180 on dot but in traffic on a hot day the creep...
one eyed willy
Pizzle fo shizzle
Lakeland FL
im using a 180*,my stock t-stat is a 192*. yes,im running 1 14" and 1 12" now.
1BADHRSE
New York
Just tested the beast once more... Just took a trip down to north wildwood nj with her.. Another 4 hour trip and she took it great other then every bump causing my exhaust to crash up into my frame... I think it's time to raise the rear... Tore the exhaust off way to many times..
Only thing i was worried about is when I was parking my car I noticed fluid dripping from what seemed dead center about a foot back from the rotor... It puddles up real quick felt like straight water no antifreeze.
My initial thought was condensation in the exhaust dripping out of my prochamber from being damaged from bottoming out... But the prochamber is fine..
I took a step back and thought I'd I may be over analyzing it... I was blasting the a/c with the windows down the whole way.. Something I never do maybe that's it...
Let me know what you think. It was surely water.. Pretty cold too..
1BADHRSE
New York
That is condensation from you A/C man, it happens to all cars.
I am just making sure I hardly use the a/c and never have seen this with my car.. Just need to make anoth 4 hour ride home lol...
