With a turbo you won't see a difference in boost. For the most part you will make the same peak boost numbers regardless, though spool time can change. For a Supercharged car the boost will vary since the boost is dictated by pulley size.Not my results SD! You could very well be right. I had no drop in boost on my pulls either. Which i agree more flow should show less boost seems to be the trend. My swap was done same day in 110 degree heat. The difference was plus or minus .2 boost on the before and after runs.
Heres my graph
Heres my graph
(wife and I have twins on the way).
HAHAHAHAHAHAHAHAAHA! Nope, hopefully a little girl and boy, but I'll be happy with 2 girls or 2 boys too. We find out in 5 weeks what we are having.You're getting turbos for your Mustang? Congrats!
all I want to know is can you take this up to 7.5k ....so far it doesnt look like a strong performer at that range .
Well did a back to back test with the frpp intake and I'm not to pleased with the reaults. Lost a fair amount of midrange hp and tq gained and held from 6000-6700rpms. This was after being tuned as well. Direct swap with no adjustments netted no gain. Additionally I already had the econo plates and 62mm bbk tb on the car. I'm working off my iPhone right now so I cant post pics or anything like that but I will on Monday once I get home
Technically it shrinks. It gets pulled in under vacuum, then back to it's normal shape under throttle (no vacuum).Did it expand as well?
Nobody has claimed their FRPP manifold has expanded under boost yet, the only thing people have seen is it shrinking under vac.And then if there's Boost, it gets Larger than normal....
Mine does the same with revs. Had my son just push it to 2 to 3k and I didn't notice any changes. JDM wants to see this thing in action. I'm not sure if I should be worried or not. It is an interesting site to see your engine really alive.
negative, it collapses in when under throttle and then returns to normal after it returns to vaccum...movement occurs on mine when I hit the throttle and then goes away when I release it.....Technically it shrinks. It gets pulled in under vacuum, then back to it's normal shape under throttle (no vacuum).
