MikeVistaBlue06
Inventor: Asshole Points
hey. like you said... its my car. i think i can easily get my motor to last around 80k miles at 700 wheel. im assuming you read the whole thread... even where i wrote that i would make around 700 pump (which is what i would be using day to day) and 800 on e85.
regardless. well see what happens. i would like to have some productive replies as to what i should do for my rear end.
thanks
Currie, Ford 9" rearend. Not only are they stronger than shit, they change gear ratios in a heartbeat. All you do is pull the axles, pull the punkin', and slide another punkin in, replace the axles and you're ready to roll. Comes in every gear ratio you can think of from super tall 2.80 all the way up into the 7.40s!
http://www.currieenterprises.com/cestore/9inford.aspx
http://www.richmondgear.com/07pdfs/RG8.pdf
It is a damn shame Ford quit using their bullet proof rearend. Every NA$CRAP car on the track has a Ford 9" rearend...
HTH
Mike
