waketek516
Pedal to the Metal!
Hey Guys,
Just thought i'd post up the pics of the oil filter relocation i did. I used the $40 Summit kit. http://www.summitracing.com/parts/SUM-G4985-1/
Install is pretty easy, just make sure you use teflon on the threads and really tighten them up as much as you possibly can.
I mounted mine on the driver side frame rail under the headlight. It seems to be the location most people use. I can now drop the filter without jacking the car up, and without having the filter knock into the swaybar and spill oil all over the PS lines.
Anyway - here's the pics:
Front End off:
Adaptor mounted on the block:
Hoses run (measure twice - cut once):
Filter bracket mounted:
So far I'm totally happy with it. No Leaks, and oil changes should be as easy as my gf's S2000 now!
Front End off:
