The Official LostSoul Thread!!
canuck power
Someone needs a nap... :shock:
burn...:clap:
cekim
Large Member
Earth
then what is causing this code (
P0151​
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
"Bank2 sensor 1" is the DS O2 sensor in the header/manifold...
Could be shorted or melted, but generally speaking this means it not doing well...
It's a little hard to see as it harnessed to the back of the DS cylinder head, but if you get the car up, you should be able to look up above the DS header/manifold flange and see the sensor and the pigtail (it is green on both my cars). Check that it isn't resting on the exhaust or otherwise FUBAR (unplugged, loose in the manifold, etc...). If not, you might just replace it - it's "fun" to get to:evil:
Charlie Sheen
Armed and Hammered
Infernum ubi sum
You guys are A-holes. I was getting ready to convince Ted that we needed to race 1 last time (my last night N/A, hopefully) and now you have him worried about that stupid engine-thingy again.
cekim
Large Member
Earth
Suddenly, I am interested in that death pool...
Can you put me down for 2 weeks - Roper throws a rod while breaking his input shaft?
lostsoul
2014 vett or 2015 stang..
Gay Area
I know of the one your talkin about. I'm wondering if that could have been the main issue long ago.(just covered up) You can open loop or stop certain codes from coming up. Should I try to test or replace it?
DirtyDogOfTheDesert said:
I am jet lagged a litte. But I think Ted will see the humorous side of my comments.
Its cool man.. I'm just burnt with this thing. Every time I think about all the issues I get mad.. until I burn some local rice on the road or a prius :evil:
ZmanM3
The Evil One
Jackson, NJ
Ghoul pool! I predict a redfire very we all know and love windows the block in 2 weeks.
lostsoul
Gay Area
HE's been hitting the track every week for the " Last time running N/A" speech. :sick:
ZmanM3
The Evil One
Jackson, NJ
If Stanley uses his silver tongue, I predict a smelly yellow manual will blow like the deathstar on Wed.
cekim
Large Member
Earth
Well, first check it out to see if there is something obvious - not all the way plugged in or melted on the header...
I wouldn't bother "testing it" if not - just replace it... As I recall you have dumped a fair amount of fuel in there at times from the plug and the cam SNAFU before that, so it could be cause or effect...
Firs things first, get some eyeballs on that puppy...
cekim
Large Member
Earth
BTW, filed under stranger things have happened - I believe that sensor's wire is the one that goes over the bellhousing and if not held up, can fall down between the block and bellhousing when you are yelling at the transmission telling to "get the !@#$ in there!"...
So, check the pigtail as well as the wire the goes over to the otherside...
DirtyDogOfTheDesert
Canada/Yemen
Ted, are you running headers on your car? Could it be that your tune is not compensating for relocated O2 sensors further down stream. That would also explain the way it rev's when cold, among other cold start issues. The O2's take longer heat up when further down.
I'm not betting on Ropers engine failure, I think he's smarter than that, he's had influences to learn from................ But, if it happens I bet $100 bucks it takes less than a year to put back together bigger and better.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
"Ghoul Pool" requires PMs or emails. $50 to get in. I should up that buy-in, just in case my car ever gets mentioned. Ted - Don't listen to these guys/gals. They have no idea how S197s work. Besides, if your car broke, I could take you home. And on the way there we could stop for lap-dances, MY TREAT!
cekim
Large Member
Earth
Ted, I don't care how many lapdances Roper performs for you - it isn't worth it...
ZmanM3
The Evil One
Jackson, NJ
Its his own fault for teaching us!
