The Extreme Weight reduction Idea thread (Comfort not included)
JesseW.
Panama City Beach, Fl
step one-plasma cutter
step two-????
step three- profit!
Na really, take the plasma cutter and cut every piece of steel that isn't stuctural. take the dash apart and cut out everything that doesnt have to do with mounting the dash panel, and put holes in those parts that do.
go to the trunk and cut out all that extra steel between the wheel wells and tail panel. there is a lot there that can go and doesnt put a hole in to the outside.
that rear speaker deck?- cut all the center out of it and rivit some aluminum in (to seal off the battery and fuel cell... when you put the carpet over it no one can tell anyways..
take the doors apart and cut the crash beams out of them, then drill holes everywhere that doesnt affect mounting the windows and door panels.
pieperz06
i need to get blown
Corpus Christi,TX
bumpers
hey i was looking through some threads and i was wondering if you ever made some light weight bumper beams.
im another one of those people that is getting rid of all the weight i can and that seamed like a good easy 20 pounds to drop
908ssp
Michigan
I will probably make some aluminum bumper beams in the next month or so. But a friend of mine removed his altogether and he said it didn't weigh very much so if I get my aluminum beams as strong as the stock ones they will weigh about 40% less so theoretically a 20 lbs beam replaced saves be 8 lbs. Not terrible but is it worth it if you can't do it yourself?
pieperz06
i need to get blown
Corpus Christi,TX
that is my problem i cant realy fab them my self my welding skills are well let than desirable on any thing past yard art and i wanted to see if any one would make a second set of some thing they had already made and i would buy them from them lol that ofcourse if the weight savings was there
are you meaning 8 pounds front and back or just one side
GrnBullitt08
Dale Jr
Northwest Indiana
The weight savings wouldnt be overkill by no means with the bumper beams...and for $199.00 each like Razors Edge was selling them for its really not worth the coin unless you can make them yourself.
2005mach1
michigan
DO NOT BUY FROM RAZORS EDGE - they took my $200 and have not shipped my bumper - going on 4 months now
Wicked97
Beltsville, MD
what you need to do is start taking stuff out untill you have a pile like this
then just put back as little as posible
also as far as the bumpers are concerned
Just cut the whole thing off and cap it
06gtmustang
ABQ NM
I have a good amount of weight off my car already and wanted to take off the front crash beam but some say the bumper cover will actually cave in with high speeds and others say it wont. Wish i had a welder to make my own light weight beam like this one
Wicked97
Beltsville, MD
I could make those here in the shop for about $125. i could maybe do it out of alumium as well. would be alittle more expensive
I could also make that rear bumper bar as well. Im sure i would be under 200 bucks on that
Tre06GTP1SC
South Texas Death Ride
El Paso, Tx
Just let me know what you guys want and ill make it
would you rather have an aluminum bar or chromoly
i could do eithir
Id be really interested to see what you guys come up with. I am interested in doing this.
Wicked97
Beltsville, MD
Aluminum of course! I would offer up my car as a guinea pig if you guys dont have an 05-09 car to test it on :)
i think we have a few laying around :roflmao:
edit: on a side note ill see if i can get the alumium to bend tight enough with out messing it up. ill post pics tomorrow
