Young Punk Build Volume IV - The game needs change & I'm the mother *@#%en cashier
Matt D
S197 Pilot
Toronto,Canada
Matt, did you get a weight on the stock fuel tank?
Not yet Art.. Im going by what Paul did.. he said it was a 35-40 lb differnce going to a fuel cell. The evap system is like another 15-18lbs with all the lines and crap.
once I have everything bolted on I will be weighing it in the shop on some scales. It will be interesting that's for sure :p
Chris06GT
Dragging LS A..
Alabama
Yeah, it's hard to get a good idea what everything weighs, until you put it on some scales and see the difference in total!!! That's when I noticed mine....
GeorgeInNePa
Clarks Summit, PA
I wish they made an electric water pump for the new 5.0.... the thermostat housing is now a bit differn't then before. Im hoping to get it running in a week or two when the rest of the stuff arrives. Open headers dam right lol
One of the Vendors, BBR I think, has said there will be one soon.
Matt D
S197 Pilot
Toronto,Canada
Matt are you aiming for sub 3000?
The car weighed 3060 last season with out driver.... so this season with the cage in the car and all my tricks I hope it will be at 2900-2950 with out driver if all the stars line up maybe even a bit less... but I don't want to count my eggs before they hatch :lol2:
05stroker
Never enough power guy!
Bullard Tx.
IW can make it for you, just tell them what you want. They did all my custom stuff from my design.
05stroker
Bullard Tx.
Should be about the same as stock one just not on the shelf. Give Brad at IW a call , he will take good care of you.
GI Joe
Yes :beer:
Im still waiting for a set of under drive pulleys or underdrive crank lol to be made.
I think ATI made a crank pulley but it's not under driven
Yes there is an I/W 10% underdrive...lemme know if you need one..
Dave
ILW84U
Edmonton, Alberta
Mine was spun on the balancer along with everything else that I could spin . It was perfect . Is there something on the 5.0 that is different ? Are they externally balanced ?
I don't know if there is any difference. I just remembered reading that there may be a problem with the IW pulley for the 5.0's & figured it was worth pointing out to Matt.
jsnyng
Alpharetta, GA
I believe Adam's issue with the IW pulley was with an overdrive pulley, and Matt is thinking about an underdrive pulley. I don't know if that makes a difference, but just throwing that out there.
Matt D
S197 Pilot
Toronto,Canada
Well I oppened up my SCT advantage software and typed in my computer code so I could start a base fire up tune. The code off the computer isn't coming up SCT says I need the strategy code off these ford racing kit's they add data dailey. Have to get power to the fuse box so I can get the ignition on and read it.
Just waiting on this fuel regulator.... once that is on I want to change the oil , get the h-pipe that im waiting for on and start breaking in the motor on the dyno and get a feel for the tuning on the new 5.0.
I think because I don't have the AC or Power steering pump attached mine might make an additional few (2-6hp increase) maybe lol
Wicked97
Beltsville, MD
There is no Power steering pump its electric
i dont think your going to see any "extra" hp :rant:
:roflmao:
