The Official LostSoul Thread!!
Screamn03
Snake in the Grass
Bay Area, CA
Crap, I was going to say swap the front 02s with the rear but looking on Alldata they show to be different part numbers.
lostsoul
2014 vett or 2015 stang..
Gay Area
well.. I'm hoping ford could check that or the harder stuff (opens, shorts. etc) and not F with the car tooo much.. right now I'm going to get some Zzz's AT&T was Fing with me also today for hours!. I found out today that they do treat their customers like their employees!
craig66
Springfield, Ohio
That Liberal Redhead girl is F'ing hot though! :doggy:
Kari Byron?
lostsoul
Gay Area
went to ford yesterday and they ran all the tests. They told me all the o2 sensors are good and everything else came up fine. They said the p0151a is an error for the runners (cmrc). So I'm still at a loss. The strange thing was when I picked up the car it was cold and the rpm didn't jump down then back up. It still stumbles when cold but it looks like the exhaust fix did help, but will require more tuning. If someone can do a test for me and load the current tune they have and change your cmrc setting and load it in the car. You should not need to drive. Just start it up and run for a min then shut off and start again. See if the code comes up. Then you can reload it back.
US-1
Banned
The ShadowLands
Think about it for a minute. You had the car tuned while you had an exhaust leak. Certain things were done to work around that even though the tuner did not know there was a problem. Now, you have no exhaust leak. Don't you think you will need to have the tune adjusted?
lostsoul
Gay Area
I stated that the tune would have to be tweeked, but still doesent explain this error code. It may mean nothing, but I want to know for sure so we don't tune over the issue(again). What is the error you get if you have the delete plates and don't adjust the tune? Someone got to know??
cekim
Large Member
Earth
P151A - Intake Manifold Runner Control Performance
Which it is important to note is NOT the same as:
P0151 Heated O2 Sensor Circuit Low Voltage
Are you trying to kill us or did I get those confused earlier in this thread? If that was me, I apologize, though it did force you to find the missing studs...
cekim
Large Member
Earth
No, it was you:samuri::
http://s197forum.com/forum/showpost.php?p=76937&postcount=160
Or did you have both at different times? I am almost as confused as you are now...
lostsoul
Gay Area
its p151a. I just checked it again. Im getting confused also. Anyway, I will get her re- tuned again $$$$
jp's performance
shooting for 11.60's N/A
mass
your tuner can shut off that error code in the tune.i had the same problem when i had the blower on my car, jms chip tuned my car it kept coming up.so i called and talk to monty and it never happened again.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
The current tuner keeps insisting that the CMPs are turned off in the tune. However, every two key cycles it comes back again, P151A.
