Alter Ego Trip
Pot Stirring Aficianado
According to that it's not such a weird idea after all.
I might give that route a try. I would like a little more low end power on the street.
that would be really interesting. wouldn't that be inefficient as hell? not to mention the car would sound like a vacuum cleaner! but i love the concept. please update us on that one
As promised, here are the graphs, the boost graph is overlayed, the one that ramps is the exact same F1R setup (not the same engine but similar, more flow now, same cid, heads and headers, only difference is a 127550 now)
Added the power/torque curve, there is a deep that was corrected later on, this is on pump+meth.
Purple is normal run, cyan is the wastegated one.
We used a turboxs dial in boost controller. Would like it better tested on a duty cycle unit but was not the case.
You could pulley it down and install a wastegate that is boost controlled so you could flat the boost around where you want.
I'll have a F1R car on the dyno with this in thursday. Car is making 22psi up top and want to leave it at 13-14 so it can be used on pump.
In theory it works, and customer commented me that it does but I have to see it first.
I'm running this setup.
I have an F1C with a 3.7" pulley, and I see 15 psi from about 4500 through redline. My wastegate is set at 15 psi, as soon as it reaches that, the wastegate opens and maintains that 15 psi and bleeds off the rest. I am getting some belt slip up top, but it's still holding my desired boost level, so it can slip all it wants.
Twinscrewgt on here is also running a similar setup on his 2011 GT. His is an F1A and he's got his set to 10 lbs through redline with a 3.85" pulley.
Anyone who knows Prochargers and F1's, knows the 3.7" and 3.85" pulleys will make 30 psi + on these cars. The wastegate allows us to run a lot less boost for pump gas, and builds boost a LOT quicker and lower in the RPM band. It works REALLY well. I've got 5 lbs at 2500 rpm. It's a smooth broad power band. It doesn't spin the tires at 2k like a twin screw, it's not on or off like a turbo, and it's not peaky like a centri.
If I did have one complaint, it would be that it makes a bit of noise. Otherwise it's a really nice usable setup with great adjustability.
FWIW, 542hp and 538tq at 14 lbs. Peak tq at 4800, peak hp at 5500.
sorry just got to see this (computer wouldn't open it up in iraq). that looks pretty interesting. as i understand it, the red race valve from procharger is somewhat adjustable. would i be able to create this same effect with a procharger and the red race? what i was thinking was hooking the bypass up to a tube (pvc or otherwise), monitoring air pressure from an air hose and then adjusting it to open up at 10lbs. does that seem like a dumb idea, or is my logic right?
and one more tard/newb question: what would be the optimal wastegate placement?
The Procharger red race valve will only open under vacuum. Under boost it's closed tight. You'll need another valve to try to control boost.
It needs to be a blow through setup with the MAF after the intercooler (or at the outlet of the intercooler like on some of the Prochargers), and then the BOV, and wastegate anywhere between the supercharger and intercooler inlet.
that confused me a little bit and shows me that i need to do A LOT more research before i install my supercharger
The big Red Race valve is just a BOV. It's purpose is to vent pressure when you're off the throttle. On the throttle, boost pressure fills the diaphram (from the top) and holds the valve closed. A wastegate works the opposite way. The spring is much stiffer, and when under vacuum or low boost the valve is closed. Under throttle the diaphram fills with boost pressure (from the bottom) and when the exceeds the spring pressure (desired PSI), the wastegate starts to open and bleeds off pressure.
so on the "stage 2" system that has the maf built into the intercooler, the wastegate would go between the compressor and the intercooler and vent where?
This is how mine is, The wastegate just vents to atmosphere, as does the BOV.
and to ammend that, the only reason i could see not to have one would be price... besides those cheapos on ebay
good call, i was worried about them having to be installed in-line, but after some reading, you're help and finally looking at pictures, i think i have a good idea now. i think at low boost, a ebay cheapo is gonna be fine insurance for me. i'm gonna do it, now i just need to figure out what size.
you sir are a god, thank you very much
