Should I change my spark plugs soon?
LordBritish
Some people recommend replacing the spark plug boots and the wire (spring).
Where do I get the boot and wire from?
dustindu4
You should be warned that brisk plugs only last about 10k miles, I wouldn't use those.
Our cars don't have boots and wires, they have coil packs, which don't need replacing.
05stroker
Never enough power guy!
Bullard Tx.
On an N/A car there is no point.
He is referring to the rubber boot and spring on the lower half of the COP.
LordBritish
OK, i've thought hard about Motorcraft vs Brisk vs Champion vs Autolite.
I think I may stick to Motorcraft and just put some of that nickel anti-sieze on it.
At least I know it'll work properly. Mine has with no problems for 40K miles since I bought the car.
I may wait another 10K miles before changing the plugs. If they're not stuck now, I doubt they'll be stuck then.
The boot i was referring to was this:
You can buy them for like $4 a piece.
LordBritish
Here's my shopping list of things I need to get
8 Motocraft spark plugs:
http://www.amazon.com/Motorcraft-SP...ake=Ford|54&Year=2005|2005&newCar=1&carId=012
$8.63 x 8 = $69.04
Spark Plug Socket:
http://www.amazon.com/OTC-6900-F-15...UTF8&coliid=IFGV707K5MYBV&colid=26EBCF678IP4F
$18.06
Lisle Spark Plug Extractor (I can always return if unused):
http://www.amazon.com/Lisle-LIS6560...TF8&coliid=I187O082M3HRWV&colid=26EBCF678IP4F
65.88
Torque Wrench (I dont own one - never did)
http://www.amazon.com/Neiko-Classic...TF8&coliid=I1ZVR3HWDEQUH9&colid=26EBCF678IP4F
$14.99
Spark plug gap feeler gauge:
http://www.amazon.com/25025-26-Blad...UTF8&coliid=IGZXR4JVE1VPP&colid=26EBCF678IP4F
$4.84
Nickel Anti-Seize:
http://www.amazon.com/Permatex-7712...UTF8&coliid=IYDMIT61XFY1Z&colid=26EBCF678IP4F
$17.26
Dielectric Grease:
http://www.amazon.com/Permatex-2205...TF8&coliid=I1EG3W47A6M35E&colid=26EBCF678IP4F
$9.54
Penetrating oil (Blaster 16-BP):
http://www.amazon.com/Blaster-16-PB...TF8&coliid=I23X0WESYDX7T3&colid=26EBCF678IP4F
$6.44
COP Boots & springs (x8) - optional
$38
Total Price (not including tax & shipping):
$244
Is it still worth doing it myself?
CandyRedGT
Illinois
I put them in my 2008 GT with a Saleen supercharger on it.
1lowtoy
I have not had any problems running Brisk plugs well over 10k before needing to change them. Which heat range plug were you having problems with?
