don_w
Dyno Numbers - Who Cares?
If you have 39# injectors, you should be seeing about 47-49psi at WOT (add your boost to 39... e.g.., 39 + 10psi boost = 49psi fuel press). At idle it should be around 30psi.
So, what does ODBII say and where is your pressure tap?So why does this scare me?
Dead, warm idle, 70MPH cruise and barely tipping in...
...I would be scared to see the boost gauge going that high though on a stock short block. Have you have it dyno'ed yet?...
...Did you install 39# injectors?...
ewww.... That's not good, it should hold pressure even if the car is off (thus the big mess you make when you disconnect the fuel line and the car hasn't been sitting for days...Yes. If I turn on the ignition, but do not start the car, the pressure jumps up to 40psi, then drops to 0 within about 20 seconds.
Any puddles of fuel under the car?![]()
...15 psi.....my shorts would need to be changed if I saw that.
Something sounds off with your boost gauge too... that other pullie is an 8lb one I bought the same thing.
...I think you have two problems.
Glad to hear it. Now Ted needs to up date his thread.
