2011 clutch options..
Trav4011
Hoosier Daddy?
Houma, LA
I'm getting tired of this crappy OEM clutch engagement.. I think that the stock clutch isn't fully disengaging between shifts, which is causing a lot of our problems with grinding/banging.
I don't want to spend a grand on a twin disc, so, what are the other options? Is this just basically a 26 spline clutch that you would toss into a Cobra with a 26 spline shaft? Or, is it different?
Travis
luillo
Fort Walton Beach, Florida
Travis
I am going on the same thing man. The dealer change the trans oil and help but end up been the clutch for what i have now. Vibration from stop until the car is moving and some sliping also a lot or grinding.
I got Exedy 700. is good for 700lbs of torque and comes in a kit with the hydraulic sleeve pilot bearing and aligment tool. $500-600
Trav4011
Hoosier Daddy?
Houma, LA
You haven't installed it yet I assume? You're having issues with the stock clutch, right? (Had a hard time understanding your post)
luillo
Hoo sorry... Yeah.. Monday the shop will do the install because i dont want to go ahead and install it myself after the headers install.haha
My stock clutch is garbage now after i installed all these bolt onse e.i:
Boss intake, JLT CAI, ARH Long Tubes, BBR Tune...
JJ@WMS
Woodbine Md
I know you said you dont want a twin disc but there is no substitute. We have beaten on ours hard with no problems. Mcleod RST FTW!!!
JJ
wbt
I installed the Ram 9.5" twin disc setup w/alum. flywheel last weekend and couldn't be happier. It is worth the extra $300 over a replacement disc and pressure plate IMO.
guilloe
Clutch
JJ
JJ
ln terms of driveability how the RST perform, how did you compare it with the stock one.
GE
Entrenched
Travis
Stock clutch is a 23 spline! The new TR6060 kit will use a 26 spline.
kyoshosp2
Baton Rouge, LA
Trav I'm pulling my ram HD out. Rated for 650 .. 873 miles on it .. I paid 543.00 shipped . 300 it's yours.. I'm going to put the twin disc I have in due to future mods lol
RDK
The Exedy 500 is out for the 2011 5.0 Tq Capacity: 525ft/lbs
does anyone know for sure if the Boss/ 2011 5.0 uses the same clutch?
Trav4011
Hoosier Daddy?
Houma, LA
Can I meet up with you and see what it feels like before you pull it? Never used a RAM clutch before.
Travis
Trav4011
Hoosier Daddy?
Houma, LA
JJ
I know.. I've been eyeballing it, too.. I can get the RST for like 650 shipped to my door.
Did your stock clutch give you issues as far as not disengaging all the way? And, did the new one fix it?
JJ@WMS
Woodbine Md
Dont get the clutch without a new flywheel.
The RST is an amazing clutch, I have about 4000 miles on it and lots of 1/4 mile passes and even when I abuse it at the track and start to smell it all I have to do is put a fan on it, cool it down for about 10 minutes and its ready to go. Feels lighter on the pedal then stock and grabs great.
Our car was one of the first ones out and when the tune allowed us to shift at higher rpm then stock the stock clutch gave up and gave us low pedal engagement. When taken apart the cover plate bolts were loose or broken so we just put the Mcleod in it and havent looked back. We have perfect pedal feel and engagement. Multiple 11.1 runs on our N/A combo as well.
JJ
Trav4011
Hoosier Daddy?
Houma, LA
Nice.. I haven't spun mine past 7K, and when the trans was pulled for a whining noise, the pressure plate bolts were all intact/tight. But, the clutch just engages very low to the floor, and I get audible knocking noises when shifting gears with the clutch depressed. That tells me that the disc is still engaged partially.
I will take a few thousanths off of the stock flywheel to clean it up if I get a new clutch.
Travis
wbt
Travis
Sounds like the throwout bearing is not working properly if the pressure plate is not having issues. Have you bled it? You can do it yourself or take it to the dealer. If you want to do it yourself let me know. I will fill you in.
Trav4011
Hoosier Daddy?
Houma, LA
Yeah, the pedal feels kinda like a sponge, and is erratic in it's engagement point.
Also, I get a popping noise and sensation when I push the clutch pedal all the way to the floor. It sounds like a spring/pop noise, if that makes sense.
How do I bleed the line? I don't see any serviceable ports to do it. Thanks!
Travis
