N/A 3V RWHP! Who has the most?
06MUSTANGGT24V
S197 Torch Red Member
Conway, AR
Ok before I have to put the flamesuit on, I am wanting to know who has the highest horsepower N/A 3V? What block, compression, and fuel did it take to get that much?
3vs197
spyder made 424? with a 5.4. several people have made 400 or so on the stock bottom end.
Booya
Pompano Beach, Florida
Steeda CAI, FRPP Cobra Jet TB, FRPP intake manifold, FRPP CNC Heads, BBR Stage 1 cams, Steeda UDP, BBK long tubes with hi-flow catted X-pipe, Roush stingers, and stock bottom. It's not the highest power, but it's an idea.
Marc s
NASA AIX
Auburn, WA
I have the most.
I raised my compression to 25.62:1, and removed the impeller from the D1. In it's place, I installed a saw blade that sticks through the hood. I now have a 700hp table saw. If I change the blade, I can cut deli meats if I get a hankering for a sandwich.
06MUSTANGGT24V
Conway, AR
Who did your tuning?
I have seen the 424 spyder made. Is this the most out of a three valve?
Germeezy3
I took a 4V, and took out one valve per cylinder.....which increases flow through the valve port. But it has a 3V bottom end so its still technically a 3V. I am running Coyote cams with a retrofitted hybrid TiVCT/Vtec sytem and 14 to 1 compression ratio. On an 80/20 E85 / Biodiesel mix I am making 483 rwhp @ 8,100 rpm. I also made sure my redline was 9,000 rpm even though the fuel cut is at 8,500 rpm just so I could impress my Honda S2000 owning buddies.
Unfortunately because of how high I rev it, I had it tuned by a reputable Honda tuner so in interest of engine longevity they detuned it to make 268 rwtq at 7,900 rpm.
Sinner
Plano, Tx
^^^ why be an ass and fuck up the thread? and now i'm fucking up the thread... good job.
06MUSTANGGT24V
Conway, AR
You must of used Hondata! You sir are win! May I have permission to tattoo your name on my forehead? That way every time I look in the mirror, I see greatness!
