08 Stroker 3v need 8 hole flexplate
Shakn68
I need advice for an 8 hole SFI flexplate for my 08 stroked 3V with a 5R55S automatic trans. None are listed since the 3v all had 6 hole stock cranks. Going with a Hughes stall converter. Will any of the 8 hole internal balanced flexplates for earlier, or later year mod motors work? Please advise...
msvela448
Yes... I used a flywheel from an 03 Cobra for mine... So if you can find an automatic car with an 8-bolt Ford modular V8 it should fit... Just check the tooth count / diameter is the same for starter engagement. Maybe a flex plate from an automatic GT500?
Sent from my SM-N975U using Tapatalk
