10% overdrive crank pulley..8 rib setup
Status
Not open for further replies.
hotairgypsy
you just bolt this over your 8 rib stock crankshaft pulley and you gain 10% instantly. If you are looking for SFI approved this not not the one you want...if you just want an cheaper way to gain the 10% this is the one...bolts right up and get ready for more boost...
$165 shipped
Mustang30212
Columbus, Ga.
Quick question...
If I use this on a 6 rib setup...would it work. It would ride in the inner or outer 6 ribs and work maybe?? lol
RH
hotairgypsy
i am hard pressed to come up with a reason it would not work...question would be is a 6 rib factory crank thinner than a 8 rib crank....i am leaning towares it will workbut i cannot say for sure....
hotairgypsy
if you can give me a thickness from the face to the center of the rib of the one closest to the engine i can do the same here and see if they match
hotairgypsy
if i did my math right my measurment is 0.591" from face to center of rib closet to engine block
Status
