BruceH
BBB Big Bore Boss 322
2008 GT/CS Built Motor, Procharger, More $23,500
For Sale $25,500.
Now $23,500
Edit: I just added up parts cost. There is over $18,000 in aftermarket parts in the car. This doesn't count the labor except for the rear end and machining.
Edit#2: The car now has Hot Rod cams in it. The dyno sheets that are in this ad are with comp 127400 cams. I don't know what the power difference will be. The sound difference is noticeable.
2008 Mustang GT/CS. Dark Candy Apple Red, Premium interior with heated power seats, 47,000 miles, original owner.
Motor is built with forged h-beam rods/arp2000 rod bolts, Mahle flat top pistons with a 3v exhaust relief, Ford Racing cnc heads, Comp 127400 cams, Comp 26113 springs, Comp 20 degree limiters. The heads have 53cc combustion chambers. Calculated compression is 10.76:1. Block prep was bore, diamond hone, deck, and main line check.
Supercharger is a Procharger D1SC HO with three stage intercooler. It has 5,000 miles on it and currently puts out 19psi at 7,000 rpms and is wastegated to 14psi. A manual boost controller is included so turning up the boost is fairly easy. BOV is a 50mm aftermarket. Pulley is a Reichard Racing 3.7".
Transmission is a 2008 TR-6060 6 speed. McLeod RST clutch, McLeod billet steel flywheel, GT500 drive shaft with dual safety loops.
Rear gears are FRPP 4.10 with a Detroit Trutrack, FRPP girdle cover, CHE axle brace, billet aluminum lower control arms, adjustable steel upper control arm. The rear springs have been changed to V6 springs resulting in 1/4" lower than stock.
Fuel system uses stock lines with GT500 pumps, 40 amp boost a pump, and 1000cc Bosch Racing fuel injectors.
Racestar wheels, 15x8 in the rear and 17x7 front. TPMS sensors are installed and work. No TPMS light with these wheels. Rear tires are Nitto 555R 275/60/15, front are Falken Ziex ZE612 235/55/17.
The motor was last out of the car in May 2012. At that time new gaskets and seals were installed along with the Ford Racing cnc heads. A visual inspection showed no concerns. Connecting rod side clearance and crankshaft endplay were checked. The block deck was checked for straightness. There were no concerns. The motor has 23,000 miles on it.
The body is in good shape, there are some normal wear and tear paint scratches. The only appearance items are a Silverhorse Racing rear honeycomb blackout panel and front side panels.
Gauges consist of the factory 6 gauge cluster, Cobalt mechanical boost gauge and Innovate LC-1 wideband mounted in a SOS piller pod and a PLX multi gauge mounted in a vent pod.
The motor has dynoed at 674/536 rwhp/tq at 6950 rpm on a Mustang dyno. It also dynoed 662/558 rwhp/tq at 6500 rpm on a Dynojet dyno. These were at 19 psi with E85. Spark was at 21 degrees of advance. The car is currently running on 92 octane pump gas with a 14 psi wastegate. I don't have a gasoline dyno.
That's most of it. The car runs and drives very well. I've done the tuning and the most important thing to me is driveability. This car drives very well in city traffic and on the highway. All emissions systems are functional and are turned on. Power delivery is linear until boost starts building. Once boost builds power delivery is strong and rapid.
It just passed Washington state emissions running on E85. It's a 49 state federal emissions car. The exhaust system consists of JBA short headers, factory cats, and a new set of Ford Racing GTA mufflers. There is a video at the end of this post.
There's more and I will go over all the details with any potential buyer. This car gets compliments all the time.
I've performed all the modification work except for the gear set up and machining. I have pictures and reciepts for the parts.
This car makes good power and has a solid foundation throughout the driveline to support the power. It's ready to go, everything that needed to be changed to handle the power has been changed. No modifications needed.
I'm selling to simplify my life.
Video:
http://s635.photobucket.com/albums/uu78/1Mustang32/?action=view¤t=MVI_1489.mp4
For Sale $25,500.
Now $23,500
Video:
