200 mile UPDATE:
car is running strong.
TURBO REBUILD AND SMOKING ISSUES:new seals in the turbo seemed to be the fix for the oil smoke screen i was leaving everywhere, currently running #3 with no restrictor and #12 drain! did about 5 heat cycles of just letting the car get to temp, then letting it cool down, then 100 miles of just taking it easy....letting it get to 1-2 PSI before backing off.
COOLANT TEMPS: are 180-185 on average @ cruising speeds....creeps up to 200 in redlight traffic with the A/C on.....if i get stuck really long in the florida heat, it will creep to 220....but soon as i get it rolling again it comes right down.
OIL TEMPS: are 150-155 on average @ cruising speeds.....hits 180 @ WOT
OIL PRESSURES: 80-90 at start up, 70 at cruising speeds and 25 at fully warm idle
A/F: is a good 11.3-11.5 at WOT
TR6060: shifts great and love the KR shifter, gearing and such seem perfect with the 3:55's i have
i havnt taken past 10 PSI yet, the tires are having a real hard time as it is.
i think i need to back the meth nozzle down atleast one size, i went thru almost 1.5 gallons on a 80 mile spirited cruise.....seems like alot!
going tuesday to the dyno , also getting my tutorial on using the SCT software!
