298....tr6060.....67mm@20 psi.....in progress!
one eyed willy
Pizzle fo shizzle
Lakeland FL
i agree, it turned out great....soon as i do some buffing ill take a few better pics to show off all the holes we filled in.
GT500KR
Quad Cities, IA
ok i keeping trying to figure out how you got a pic of your car infront of 2 5o's?? im intrigued... thanks
one eyed willy
Pizzle fo shizzle
Lakeland FL
downpipe roughed in, looks real good, had a buddy come over with his GT so i could check my clearences....lots of room to spare!
taking my power steering lines to a shop to see about adding a flexable section so i can get them out of the way for the up-pipe!
one eyed willy
Pizzle fo shizzle
Lakeland FL
Couldnt you get some braided PS lines from Jegs or Summit ?
possibly! i removed the lines, need to take them to the store to figure out what size and threading they are.......i have no clue, i figured i would take them to a place that works on high pressure hoses and see what they suggest.....im planning 100% to have them re-routed away from the pipe for sure!
05stroker
Never enough power guy!
Bullard Tx.
Two things that will never leave my car is the power steering and power brakes... We are talking aprox. 10 hp between them both.. JMO. Good luck!
one eyed willy
Pizzle fo shizzle
Lakeland FL
My buddy Kevin came down and showed me how to use the line bender.....turned out great, so now there is PLENTY of room for the turbo pipe! there are 2 power steering lines that where in the way, a long one and a short one....so we moved the long one to where the short one was and that gave us plenty of slack to rebend out of the way.....so know I just got to get 1 line extended 14 inches! i got one spot where the up-pipe is hitting the oil pan, so i just have to ding that section in with a hammer to gain some clearance!
05stroker
Bullard Tx.
call me a wuss but p/s, p/b, and a/c is a must...
The only reason I have no A/C is do to the crank support I built and I didn't allow for the compressor. After things are running good I will swap the spacers on the support to others that are 1/2 bigger and the A/C will be back in business.
GB10
8s coming soon?
Burleson, TX
If you go to napa they have various sizes and lengths straight tubing with flared ends and tube nuts already installed. You can just find a length that will work and bend it to your needs. They may not have it since it may be metric, but it would be easier than extending the other line.
one eyed willy
Pizzle fo shizzle
Lakeland FL
thanx,ill look into that!
