3v 298ci Pro-Series Rotating Assembly, ARP Hardware, Oil Pump
Rpm427sc
Portsmouth VA
I have a used 298ci rotating assembly from Livernois Motorsports for sale. 9.8:1 Diamond Pistons STD bore, good for 1000hp. One of the pistons is damaged and you will need new bearings/rings to complete it. I will list everything separately in case some people don't want everything. I paid $2300 for this rotating assembly new.
**SOLD***Livernois Forged Steel Stroker Crankshaft (Kellogg) good to 1200+ HP and modified on Livernois in-house CNC for enhanced oiling under extreme loads and RPM, Shot Peened and Polished, Produces 298ci. 8-bolt. Can't get better then this unless you go with a $3k+ billet crank. - $700 Shipped!***SOLD***
Diamond Coated Pistons, custom through Livernois. About $1000 new for the set, so one replacement piston might run around $125. I'm selling these for only $200 for the set, so this could potentially be a great deal for the buyer.
**SOLD** ARP Head Stud kit, 12-point head ARP2000 series $300 +Shipping. PN 256-4202. No wear, look basically brand new. Great deal since they are $430 new.
**SOLD** ARP Main Stud kit w/ windage tray, 12-point head ARP2000 series - $199 + shipping. Same as above, look basically brand new.
***SOLD*** FRPP High Volume Oil Pump and Pickup Kit. $50 + shipping. Used but in great shape. ***SOLD***
***SOLD*** Manley Forged Steel H-Beam Stroker rods w. ARP2000 bolts. -$400 + shipping. ***SOLD***
BruceH
BBB Big Bore Boss 322
What are the sizes of the pistons and rods? I'm talking about the compression height of the pistons and length of the rods. Livernois has done a stroker combo in the past that had a piston compression height of 1.095 and rod length of 5.950". Also, what size are the rod crank pins?
Thanks,
Bruce
Rpm427sc
Portsmouth VA
I just Mic'ed the rod journal on the crank at 2.000in
I'll need some more time to find the specs of the rods, unless you can figure it out by compression height.
Makdaddy
I am Dysfunctional
South of Chicago
So $1400.00 for rods 7 pistons and the crank?
can you still get a matching piston?
Or have you checked?
BruceH
They should be the "normal" 5.850" to go with a 1.200 compression height. It would also put the crank stroke at 3.750".
The crank already has Mallory metal in it. That will save the buyer money when it comes time for the balancing.
Rpm427sc
Portsmouth VA
I'll call Livernois in the morning and see what the deal is.
Thanks for the helpful info Bruce!
Rpm427sc
Portsmouth VA
Interested in the head studs but where is it new $430?
http://pages.ebay.com/motors/link/?nav=item.view&id=191034889467
Can you do better on the price?
Sent from my HTC One using Tapatalk
How about here:
http://www.livernoismotorsports.com/products/Ford-Modular-4.6L-2%26-4%252dvalve-12pt-head-stud-kit.html
http://www.lethalperformance.com/sh...0-series-cylinder-head-stud-kit-12-point.html
http://www.summitracing.com/parts/arp-256-4202/overview/
And why don't you read the rules before you post here:
"Originally Posted by stkjock
There has been a lot of posting in for sale threads of late that have become a "price" debate. This type of posting should not be done.
If you don't like the price either make an offer or send a PM don't post some BS like "Hey I can buy these $100 less down the block".
If you can buy them for less, go buy them, don't fuck around in the thread.
If you have no intention of buying a listed item, move along, don't post.
TIA for your cooperation."
roberts
Bonne Terre, Missouri
Man only if u had this forsale about 1month ago before I started buying stuff for my
Motor! Good luck with sell
Makdaddy
I am Dysfunctional
South of Chicago
Bruce if its a 3.750 stroke wouldnt that put it at 302 CUI
he has it listed as 298
Ryan
I also need specs on the pistons what alloy YADA YADA Sorry if I missed that somewhere else
Rpm427sc
Portsmouth VA
Ryan
The pistons are Billet Forged 2618 then CNC'ed. I posted the spec sheet above. Livernois said they can replace one piston no problem, about $150 and 2 week lead time for these "Non-stocking" pistons. They just need the PN and Job number, which I have. You will also need new round wire locks (cheap) and new rings (duh).
sportinawoody
Piedmont area , N.C.
No. it makes 298 unless you use a .020" piston. with a 3.800" stroke its 302 or an eagle 3.75" crank with a 5.950" eagle rod and 1.095 comp height piston also makes 302 in standard bore. this is definitely a 298 until you change piston/bore size. dont ask me how i found this out.
Makdaddy
I am Dysfunctional
South of Chicago
Thanks
Did you sell any of the ARP stuff?
I may make you an offer on all of it
Ok that makes sense, but im glad I asked
