4.0L Auto To 4.6L Manual Electrical Question?
Wolf Mxbee
So I completely finished putting my freshly built 4.6L into the car and rewired the harness and tried to go and start it, I hear everything ready to crank except.. the starter luckily I’m good with diagrams so I traced it down to the auto shifter position switch which I suppose I can refer it to the safety neutral switch..? The car doesn’t want to crank because the starter circuit is not being complete.. any ideas?
Norm Peterson
corner barstool sitter
RIP - You will be missed
It looks like you could jumper the RD/LB wire at connector C167 to the WH/PK wire to at least check to see if that's where your starting problem lies. Just make sure you've got the transmission in neutral.
Norm
Wolf Mxbee
Thank you I seen on another forum reading up to this, and will try it, thanks for the help!!
Macman45
Resident Geriatric
Atlanta / Bay Area
I believe Norm nailed it, short out that auto tranny neutral switch, but a future move would be to wire that to the clutch safety switch...
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Are making it an automatic, converting to manual, or what?
If it was an automatic and you're keeping it auto, nothing should have changed to keep it from starting. However, as shown in the bottom part of the diagram, the DTR on the V8 transmission, or a wire to it in the V8 harness, might be open when in park or neutral position. It should also start when in neutral, not just park.
Just got to make sure: was PATS properly taken care of with the PCM swap?
Wolf Mxbee
Correct two swaps essentially and yes I made sure pats was disabled on all of my tunes and soon future tunes as well, I have yet to try the wire bypass for the shifter but attempting right now as I type this so will post the results, thanks a bunch guys!!
Wolf Mxbee
Alright so update!! I actually had to reach under the car and go to the auto tranny harness I’m converting to manual. So my mustang is an 05 factory auto V6, I am putting a v8 manual into it but using a auto v8 harness and only using two connectors and rewiring them to the manual trans sensors but the 12 point connector to the auto trans I had to cut the two wires you guys listed above and wire them together, I also found out the ecu had a weak ground so once solved it turned over right away but won’t start but expected
