8” sub in door pics
Hollowdweller
Did some playing with the 8” Fosgate shallow mount in the doors today. Turned out pretty good I thought. 3/4 spacers….gonna try a 1/2 spacer on the passenger door I think. Probably gonna rattle to much to really use but hoped it’d look cooler than factory
pass1over
I like it LOW
Trenton, FL
if you feel like getting rid of some of the spacer, you can stretch the enclosure in the door cover.
I took mine off, put some weights in the bottom of it and applied heat to the underside with a torch, evenly. It heats up the plastic stretching it out and makes the opening deeper. I have Kicker Comp R subs in my doors (they're 4-1/8" mounting depth) with only a 1/4" spacer.
lwarrior1016
mississippi
you guys are giving me ideas. I need to replace my factory door subs. Both of them are blown.
Do you have any pictures of your install?
