Norm Peterson
corner barstool sitter
You're missing the point. If nothing else, you're maximizing what the S197 could have been. Or in other words, hotrodding.Forget the $10-$12K mod. Just buy a 2015-2016-2017 car.... which has oem adjustable rear camber.... from zero to as much as -2.7 degs. Plus IRS. The 05-10 cars are long gone obsolete in every aspect from engine to tranny to suspension, lack of irs, no rear camber adj etc. The 11-14 cars are not far behind.
For up to about a degree - about enough to compensate for the axle's own roll - there is at least one far less expensive way. Even if you have to buy the equipment to do it with.Sure you can add neg camber to the rear....for $10-$12K, but now you require deep pockets to 'fix' issues that should have been addressed earlier.
Norm
