are 2v cams the same as 3v?
19COBRA93
Ford Racing
Clinton, Ut
Not even remotely...
2V cams operate 8 valves per head (8 lobes).
3V cams operate 12 valves per head (12 lobes).
Mikes_BLK_GT
Mid-Life Crisis
Pacific NW
If you have to ask then NO cams for you..................LOL does the square peg fit in the round hole?
Boozshey
Tampa
I think this is the first I have seen a vendor call someone out.. haha
cantdrive55
San Diego-ish, CA
irishpwr46
Official Site Vandal
NYC
dont listen to all these people OP. they are fully interchangeable. just follow the same directions for a cam swap, but only torque everything to two thirds of the 3v cam specs seeing as you will be a valve short and will only need to torque to 2v specs
HellsBells
620/677
SoCal
Yeah I'm not sure why everyone is making fun of you. The 3v cams fit just fine in 2v. Just skip all the steps for the 3rd valve. I'm not sure if you're supposed to torque to 2/3 on all the bolts. When my buddy did it, he just torqued the bolts to the specs but he hand tightened every 3rd bolt.
JoshK
Modder AKA Fuel
Nebraska
make sure you use locktite on the handtightened bolts though:thumb:
fdjizm
Drag Queen
It only works if you perform a valve delete on the 3v effectively making it a 2v them the cam should drop right in, but not before the jackstands give out of course.
