I've been hearing a strange rattle noise in low rpms coming from my rear, so I jacked it up, and I ran into this. My driver side part of the axle is covered in what looks like oil. It looks to be slowly leaking out of the tube.
I'm thinking about turning it in under warranty but I'm not sure if they will service it due to the tune. Any suggestions?
REAR DRIVE AXLE VENT—OIL LEAK TSB 12-8-15
FORD:
2011-2013 Mustang
ISSUE
Some 2011-2013 Mustang vehicles with the rear OTHER APPLICABLE ARTICLES: 12-05-08
axle vent on the left (driver) side may exhibit a fluid WARRANTY STATUS: Eligible Under Provisions Of
leak from the rear axle vent. New Vehicle Limited
Warranty Coverage
ACTION Warranty/ESP coverage
Follow the Service Procedure to correct the limits/policies/prior approvals
condition. are not altered by a TSB.
SERVICE PROCEDURE limits are determined by the
identified causal part and
1. Inspect the rear drive axle assembly for an oil verified using the OASIS
leak from the rattle cap vent located on the left part coverage tool.
side of the vehicle.
OPERATION DESCRIPTION TIME
a. If oil is dripping from the axle tube vent, 120815A 2011-2013 Mustang: 0.4 Hr.
proceed to Step 2. Inspect, Clean And Reseal
The Rear Axle Vent,
b. If only light oil residue is around the rattle Includes Time To Adjust
cap vent, this is a normal condition. This Fluid Level (Do Not Use
article does not apply. With Any Other Labor
2. Remove the rattle cap vent from the axle tube. Operations)
Clean any oil residue from the axle tube using DEALER CODING
Motorcraftâ Metal Brake Parts Cleaner. CONDITION
BASIC PART NO. CODE
3. Apply Motorcraftâ Thread Sealant with PTFE to 4010 42
rattle cap vent threads, reinstall the rattle cap
vent and torque to 20 N•m (15 lb-ft).
4. Check fluid level and set the level 5 mm
(3/16²) below the fill hole.
PART NUMBER PART NAME
XY-75W140-QL Motorcraftâ SAE 75W-140
Synthetic Rear Axle Lubricant
XL-3 Motorcraftâ Additive Friction
Modifier
PM-4-A Motorcraftâ Metal Brake Parts
Cleaner
TA-24 Motorcraftâ Thread Sealant with
PTFE
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine
Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin (TSB) was
current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is available
through Ford Motor Company’s on-line technical resources.
Copyright ã 2012 Ford Motor Company Online Publication Date August 17, 2012 PAGE 1
