TonyN
Ford Junkie
So, I have been thinking abouts cams. I am being cheap and lazy so I am probably going NSR. My question is for those with the Stage 1 BBR's. The BBR John guy on these forums says that they are NSR and DO NOT require springs in a few threads I found during my research. It appears that there isn't a lot of folks that run BBR cams, therefore concrete info is hard to come by.
Now, if you look at the Stage 1 cams on BBR's site, they say "Recommend Replacing Valve Spring". I see that they use a .480" lift where as most other NSR cams use no more than .450".
Basically I am wanting to know if those with the BBR stage 1's retained the stock springs and how is it working for you? How much hp tq gained? Any dyno graphs?
Any opinions on this?
I am hesitant to go with the BBR's because it appears that they have double standards. But I would like to get the best bang for the buck and a good tune to go with them. I read that power gains are comparable to the Comp NSR Stage 2's. But I like the fact the BBR's actually have a noticable idle. The Comps sound nearly stock. Although I prefer power/ET's over sound. Sound would just be a bonus.
Yes, I am aware of the thumprs. But I also read that people are having driveabilty issues every now and again. If I did go with thumpr's, I'd go with stage 1's. I don't think there is much power to be gained with them.
Thanks!
Thanks!
