Kaane
The flares are mismatched. The rears are completely different style. Front's look awesome. Rears need same treatment.
function > form.
Thanks for those who have responded with their previous experiences. I have now decided to go a different route with wheel and tire set up. I just thought it was a balance as well as finding the right amount of rubber for the cars power level as well. Why have 345's in rear if it can't spin 315's? I'm understanding now that it gives you that grip for more cornering capabilities too now. I though it might be better too to save weight.
Can't spin 315s? Hmmmm you sure you're in a Mustang? You don't want to be spinning anyway - sideways is not fast![]()
My recommendation for non-competitive track days is to run a 295 street tire on an 18x10. It's the easy button for low (well, lower) costs, good longevity, ability to rotate tires for full use and there are a lot of 285 and 295 tires that will fit that wheel.
For competition use, first make sure you are rules compliant. After that, if you want to preserve the stock fenders I recommend either running the less expensive 18x10 with 295 tires, or the 18x11 with 315 tires. Beyond that you can really go crazy. And to address the "spinning tires", when you are exiting a corner at a very high speed and want to start accelerating for the straight, more tire helps a lot. Every time, without fail, we have added wider tires in the same compound we have dropped our lap times.
I am really wishing TSW made 18X10 wheels...
Usually on the heavier side. If you want 18x10s I recommend APEX EC-7:
http://www.trackspecmotorsports.com/apex-wheels-s197-mustang-ec7-18x10.html
I didn't realize you could put a 18x11 with 315 tires on the front, with stock front fender's. How much camber is used? This must barely fit. Is a spacer used, how thick?
Why would you buy those when you can get a custom fitted set of 18X11" for about the same price?
http://www.vorshlag.com/product_info.php?cPath=141_142_268&products_id=624
TSW's rotary forged wheels are actually extremely light and pretty affordable, especially the interlagos.
