Cams and tuning ? 2011+
stang8psi
Slower,Lower Delaware
A few questions.
1. Who has the best prices on cams for the coyote platform, custom grind/comps? either one ( pro/con for either?)
2. Who can and has tuned them to get the drivability and the most power out of them?
3. Car will have a plate kit on it 150 shot.
4. Who to the above questions can and has the best e85 tunes for a built 11.5:1 motor with Said cams above 47# injectors, BAP, boss valve springs, nitrous plate kit, boss intake mani, intake, long tubes, full exhaust. Also when a e85 tune is purchased do you also get a 93 pump tune for the instances where E85 is not present?
onebadgsx
Houston, TX
Cams aren't really proven yet, other than the boss cams. All the big guys run them.
Lund for tuning
E85 and 93 tuning Lund.
ford20
White Plains,NY
Here is one that was done by Lund & PBTH.
Mod list is
Comp cams stage 3
JLT carbon intake
Axle Exchange DS
Forged Oil pump gears
Locators
Kooks LT 1 3/4 no cats with the Boss H pipe
Lethal Performance over the axle pipes
Stock mufflers
JLT passenger catch can
Barton shifter and bracket
Lund dyno tune
MMR cooling mod
Steeda springs and lower control arms
Steeda pan bar and bracket
Whiteline upper control arm and bracket
Ford Racing SS clutch line
Ford Racing tranny cooler
SS brake lines with Stoptech fluid
AeroForce gauge with Roush pod
DRIVER MOD ;-)
When they added the Cobra Jet intake with IIRC the 65mm Cobra Jet TB they made 501HP & 370 ft/lb.
ochoblanco
Slow 4v Member
Waco, Texas
He has stated before he won't tune a car that has cams.
I haven't seen any cams on the market outside the boss cams with proven results yet (doesnt mean there aren't any, I just haven't seen any). He can and will tune the boss cams...and does a great job at it.
08StangGT_CS
San Antonio, TX
See sig. I got them but the tuner did a crappy job. Hate driving my car ever since.
If I had to do it again I wouldn't buy them.
Maybe would have been a different story if it had been tuned right.
Stay away from Auto Adrenaline Performance in Stafford.
stang8psi
there are pleanty of cars that have the comp stage 3's and are making close to or over 500 rwhp N/A. The boss cams don't need to be tuned really, it would be no different than saying shaun I have a boss and need a tune!!
I do know JPC has custom cams for $890.00 and they are the ones they used to achieve the 507 rwhp N/A car, but they also want $$$ to tune it!
and for the money boss cams cost I would rather do the comp stage 3's..
L&M for cams! Custom grinds. Don't shop by price alone.
Lund Racing for tuning
CPRsm
That's because he doesn't know how to tune for them..... :roflmao:
Doubtful. It's the same as tuning stock cams. But ea set of cams will need a completely different cam tune since the timing events are completely different. You can't just do a remote tune w 10 revisions and think you're going to get it right. Base cam timing takes a while to get right.
kdanner
Austin
How many records does he hold again?
That reminds me, Calvert set the A/SA national record at Sacramento Raceway in his 2010 CJ the other day. You know, the track that lying Shaun goes to, and claims the track is longer than a quarter mile so he can't run any better than he does.
CPRsm
Yes, whoever holds the most records is the only good tuner!!
