AutoXRacer
A) Why does it consume 1 qt per 1000 miles ?? That's 5 qts in 5 K miles !
B) where is this 1 qt going to, if it doesn't collect in the catch can...or exhaust ? It has to be going some where. You don't see oil leaking anywhere, so the mystery missing oil gets even more baffling.
C) have you got cats installed ? If so, and oil ended up in the exhaust, it could damage cats, with 1 qt every 1 k miles.
There is some fundamental root cause you are missing somewhere. Run it past some eng type..and see if they can come up with a test to evaluate the oil flow system as a whole.
Oil isn't getting to where it should. Parts are not being lubricated. Oil consumption is nuts. What are you using for an oil filter ?
Hey Jim!!!
A) Engine builder claims its due to the low tension rings and forged pistons. Short trips on the motor doesn't help either from what I am told. I have spoken with several engine builders and 1 quart per 1,000 miles is not that uncommon for loose tolerance motors...even in modern motors. At least thats what I am told. I burn 1 full quart on a track day, 5x20 mins sessions. Thats what the new Corvettes burn...but they don't burn much on the street though.
B) The exhaust is a little dark, but not that bad. I do see some oil on the spark plugs. So its definitely going through the exhaust. No leaks and no blow by.
C) No cats...
You did mean 10nm (89 in/lbs) right? Must have, 89ft/lbs would have probably broken the bolts or pulled the threads out of the heads.
-Steve
Hi Steve, sorry, yes I meant in/lbs.
Gerald,
I'm no engine builder nor do I claim to know what's going on with your several different issues.
But ..............
I don't mind sharing a few thoughts with you if that was my engine.
I would be finding out No-Matter who or what Shop I had to get with why the heck it's going through 1-Quart of oil every 1K miles.
That's just simply ridiculous these days ............
And there is No-Way I would put it back together unless someone found out why those Cam Followers looked BURNED-UP and Seized.
There seems to me to be Multiple issues buddy and I'm just saying if it was mine I would be getting some professional to look into it.
And to have to mix different weight oils to try to get around it going through a quart every 1K miles is crazy.
That's a very expensive engine to run if you were a person that put a lot of miles on it.
Bottom-Line is for what it's worth buddy there are just to many things that are out of whack and you need to find out what the heck is really going on.
And like I said if it were mine I would be doing exactly what I have said in this post, get some professional help !!!
Terry
The plan is to prime the motor and see how much oil gets to the heads...if all the lifter bores and cam ports ooze oil, I'm slapping it together and hoping for the best.
If it desintergrates at the track, then a new Coyote or LS7 is in my future... Kidding about the LS7. lol
I really hate this motor...its be a nightmare since day one. I should have just bought a 2013 GT500 and called it a day.
