Chasing Superchager Belt Issues/Engine Knock/Clutch problems
GT500KR
Quad Cities, IA
HAHAHA your awesome!! great post. i am working 7-12s midnights and have been for 2 months now. and i have 5 more weeks of this shit left. no days off. gonna call AAA in the morning and have them tow it to my storage unit and let it sit till i get some time off.
crown thanks for the help man.
so OEM ford rockers and such or trick flow? that any better? looks like the best is billet jessel stuff and its insanely priced.
and where do i put the lock outs? in the advanced spot or retarded or or?? from what i can tell you open that back plate and put one into the tightest open hole...?
GT500KR
Quad Cities, IA
CAn't point the finger at the 2v tensioners completely.. as I have no real deconstructive testing that I can refer to..
With that said, Ford rarely re-designs the wheel for the hell of it. Possible they were on to this when they went to this valve train and the 2v were too troublesome in this system. Again, they don't just make changes to keep their guys busy.
They sure do seem to be a common thread with broken guides on the 3v tho... and a few lost motors as a result
JEEZ looks like ill go to plastic now. cause i broke a guide and now this issue. got 60k+ miles on plastic ones :/
crownaviation
http://www.tudyno.com/
Broke dafuk down
and also it ran great up until i went to pull out of security check point at work and it started doing that phase knock thing again... and then died all together..
crown... wouldnt the motor still run with a dead cylinder? it wont even fire at all... :/
And sorry I missed this question. But yes,, with a dead cylinder it would run. I have seen one run with a rod hanging out the side. Started back up too.
YOu have a timing issue and that far out it wont start, run, nothing.
NOT WORTH TRYING.. get it hauled home
GT500KR
Quad Cities, IA
k thanks
crownaviation
Broke dafuk down
The lockouts (and limiters) come with pretty good instructions (and they are cheap). If you have any doubt give me a call and I can walk you thru it. You can only lock the cams full advanced with the lockouts. You could use the TFS adjustable crank gears to retard them based on what cams you select. I do prefer these tho. I have a used set you can have. I had lost the damn center spacer and ordered new ones before I found it lol.. New are cheap anyway.. like under $50.
If you choose the limiters (maybe better for your setup) then you wont need the tfs adjustable crank gears... and can still have a pretty good selection of cams
No on Jesel. You could almost build a new motor for what those bastards cost. We will never take these motors to the extreme where they would be required or even highly recommended. I think I may even back out of them after all.
As far as the TFS followers.. well retail they are likely cheaper from what others have said but I think I can get close to that price anyway with genuine Ford parts. You only need a few, 12 at most and not sure if you can buy the TFS individually or not but have not checked. Would not surprise me if they were all made by the same place lol.
GT500KR
Quad Cities, IA
you can buy the TFS individually from propower/modmax
i guess i need to talk to livernois or compcams and see what i need for lock outs and stuff depending on the cams i need?
GUESS i cant assume that the factory follower just "failed" need to look further. maybe it was force to fail based on it wont run at all. and when i crank the engine it doesnt sound right at all. im wondering if something is hiding behind the front cover or maybe that pin snapped on the phaser
livernois cams good?
crownaviation
Broke dafuk down
Call michael at L&M for cams. http://www.lmengines.com/. (215) 675-8485. Might be more affordable than you think and he can give you more info in 10 min than I could in a lifetime
I really did like the comp 127350 with that setup too. They are affordable but have no personal experience with livernoise cams. Had a couple "rough" experiences over there buying parts (well, trying to) so never went back. Their lockouts and limiters are good.. I only buy from them if I can order online.. and not talk to those idiots that answer the phone over there. Maybe it is better over there now, but mine is a big ship that is hard to turn back around lol.
GT500KR
Quad Cities, IA
questions... possible to remove the oil pan with the trans in place? to prevent me from pulling the motor again?
skwerl
tree hugger
central Florida
Yes, you should be able to. I pulled mine with the manual trans in place but I can't see why an auto bell housing would affect the oil pan clearance any differently.
crownaviation
Broke dafuk down
Never pulled the pan with stock k member with motor in car. It should, but you may need to just lift the motor a little to get it to clear the stock k. If you have the bmr k then it will come out no problem.
Your issue will be the oil pickup tube and maneuvering the pan around the stock k.. You "might" be able to get the pickup tube off but not sure you can reach the 10mm fastener that attaches the pickup to the windage tray stand-off. You can get the two 8mm fastheners off that attach to the oil pump but will be tight getting the one off in the back. If you could remove the pickup then will come out easy
Let me know tho.. I would like the knowledge
Kylar
CT, USA
Just browsed this thread and man, we must be related because i think we have the same luck! haha :beerchug2:
GT500KR
Quad Cities, IA
ive had some good luck in the past with cryogenic-ally freezing brake rotors and brake pads along with competition go kart parts for making them stronger. think ill have these new followers frozen too. thoughts?
skwerl
tree hugger
central Florida
No. If the engine is working properly then the process is not necessary. Lots of guys push a lot more horsepower than you on stock followers without issues.
If the cause of failure is not resolved, then the new followers will break just like the old ones regardless of any cryo processes.
GT500KR
Quad Cities, IA
ok good point... i still havent taken motor out yet. but i am pretty sure the phaser is to blame. ive researched alot on here and other forums and seen stock mustangs and f150s break these followers. i was just thinking of freezing them for added insurance.
i just really really REALLLLY dont want to make it a habit of pulling this motor every other month!!! yea im getting good at it but... still... know what im saying? i enjoy working on it... but i enjoy driving it better..
skwerl
tree hugger
central Florida
I'm just saying the followers aren't the problem. Focus on fixing the problem instead of trying to put band aids on the symptoms.
GT500KR
Quad Cities, IA
im not putting band aids on anything. im just having an idea. im locking out phasers end of story. im buying new cams and valve train. like i said before.
