Clutch problems
gil_t2
Love Nitro in the Morning
Northern Va
Soooo.......should i go ahead and throw a shim in there? anyone put a shim in and had to pull it back out?
It's more about the measurements than the type of clutch. You want the TB to be in the middle of the stroke. Some don't need it but the release point ends up close to the floor.
redstangs9308gt
If you are running a mcloed rxt/rst twin disk and a mcleod steel flyweel and a factory 05-09 slave then you will need one. I believe when you purchase a Mcleod flwheel clutch package it should come with a shim. :stooges:<Mcleod tech support:roflmao:
bigray327
League City, Texas
Fuck McLeod. They should include the shim and instructions with the kit. The first McLeod asshole I meet in person is getting his ass kicked.
bigray327
League City, Texas
Did he mean a shim behind the TOB or a shim between the inner disk and the floater?
redstangs9308gt
I meant shim behind the slave. Put the shim on first then the slave and make a shit sandwich:)
redstangs9308gt
I adgree. I don't understand why everyone on here speaks sweet nothings about Mcleod. I have had nothing but problems out of Mcleod. Beside the shifting issue bull shit with the rst 3650, lets not mention the chattering sound that would come from the POS at low rpms while cruising town.
My RST for the 3650 was flawless with a fidanza billet aluminum flywheel. Loved it.
Im wondering if i have the wrong part number somehow since it doesnt have it written on the fingers like usual we shall see when i send it back.
Yeah i mean theres always that 1-2% that get a bad part or wrong part and have issues believe me it sucks big time.
I will let everyone know what I find out.
redstangs9308gt
If this helps out anyone, my rxt had numbers on the fingers written with white paint, just like the rst did for the 3650
gil_t2
Northern Va
im curious as well with there being 2 different part numbers for the clutch
The different part numbers are because 1 is for use with their flywheel and the other is for use with factory flywheel
one eyed willy
Pizzle fo shizzle
Lakeland FL
The different part numbers are because 1 is for use with there flywheel and the other is for use with factory flywheel
yeah, i only know this because others have said it here on the forum....nothing to indicate this when ordering though.....so whos to say they got the right one. if you go to lethals web site, they only list one part number, and it dosnt say anything about what flywheel to use....and its not the same part number im using....
gil_t2
Northern Va
I posted the part numbers a couple week ago, i can't remember the thread i put it in
gil_t2
Northern Va
6912 will not work with factory flywheel must have Mcleod wheel , The 6913 will work with the stock flywheel.
