… installed the old clutch combo - to compare the numbers .
Result : with the used Valeo Set up from the factory the preload is 0.840 inch / 21,34 mm in this case the steel fingers are looking over the top of the clutch because the clutuch plate is worn .
Looks like I need shims
to bring the preload up to an inch . Hope that summit has 1/2 inch spacer / shim .
If I use this one i am at 0.940 inch /23,88 mm
Longer screws are the smallest Problem we habe billions of metric stuff here
