Comp 127200 & 127300 Camshafts $500 per set!!
JimIII@JDM
I have a couple of cams here in stock that were removed from damaged race engines or had Rocker Arm failures and scored one cam and left us with only 1 good cam. Most of these have only a few hundred, all have less than 1,000 miles on them. Each cam has been inspected and cleaned by our Engine builder.
These are Comp Part #s 127300 and 127200. Both cams are excellent choice for street cars with bolt on's or Superchargers. I ran both of these in my own personal street car a few years back and they were awesome. Nice "cammed" idle quality but still very drive-able.
I can get a New Matching opposite side to each one of these cams and sell them as a complete set in perfect "near new" condition to anyone interested. The Price will be $500 + S&H per set. Call 732-780-0770 to order or PM me here. NOTE: 1-2 weeks delivery time.
That is over $200 off retail pricing!! Good way to save a few bucks and reap the benefits of some some really nice cams!
Here are the specs on each cam....
Comp 127200 NSR (No Springs Required) Direct Drop in!!!
Stage 2 - Solid Power gains above 4900 RPM, compatible with stock valve springs. No Tuning required, best with 3.73 gears. Great idle!
operating range: 750-6400 RPM
Duration: Intake 261 / Exhaust 278
Valve Lift: Intake .450 / Exhaust .450
Lobe Sep Angle: 115.5*
Comp 127300 VSR (Valve Springs Required)
Stage 2 - Serious Street Cam! Noticeable idle. Solid power gains above 4400 RPM, requires spring upgrade and tuning. best with 3.73 gears.
operating range: 950-6400 RPM
Valve Lift: Intake .490 / Exhaust .480
JimIII@JDM
JimIII@JDM
TTT
Now only 1 Set of the 127200's left! 2 sets of 127300's available.
Blackbird1084
No the mutha thumpr's are 127020. Those are from the xfi line.
psycho bob
FISTER
Tulsa, OK
Check the comp cams site. If I remember correctly these are vsr cams. Valve springs required. The spr line is springs and phase limiters
Blackbird1084
The 127300's don't require limiters, but do need valve springs. Psycho bob is right.
Dan748
France Auvergne
H,
I'm doing track days with my 2008 Mustang.
I was hesitating between the 127200 and 127300. I was afraid that the latter, with its stiffer springs, would put more stress on the valve seats for 5 more hp.
