Does ForSCAN work on our cars?
Mark_K
Denver, CO
I have a 2015 F150 and got introduced to ForSCAN to set various things in the BCM and other modules. Does anyone know if ForSCAN will work on my 2011 Mustang GT? I want to change how the unlock button on the key fobs works, deer in the headlights mode, the lane change turn signal duration, and a couple other settings that I like.
Thanks,
Mark
Ryan D
Southern Kentucky
Can't speak to an '11.. but last week I was able to turn off my TPMS warning with FORSCAN on my '08. I didn't add sensors to my drag radials/skinnies and got tired of clearing the alarm repeatedly.
07gts197
Naples, Fl
Yes it does but I’m not sure there is that much to mess with like your f150.
13v6
There is no Bambi mode and not much else you can change. You can program your keys, change the gauge pod, maybe turn off TPMS. The '15+ have a lot more functionality.
This is the best video I've found for using Forscan without a spreadsheet. If you're not familiar with Forscan you may want to watch from the beginning otherwise you can pick up at about 6:05
_E85
I used FORScan on my 2011 GT to program a new set of keys (PATS) and enable an aftermarket rear view camera. Worked fairly well.
LarryJM
I used it just talk to the newly installed premium cluster in a 2014 Mustang GT and program new keys. I had to pay the $10 as I was not good enough knowledge wise to use the free software. Once I paid the $10, it was a breeze. Have not used it since.
