It really doesn't get more tech than this: Torque, inertia, center of gravity
It was amusing how heated the discussion got, yet...Polite..
Robin Parsons: This statement makes some kinda strange non sense to me...
Wimms: First, this wasn't polite.....
I kept waiting for the gloves to come off and that was the worst of it.
Damn. S197 has ruined me.
Ok I only understood about half of that.
He is missing the point that a large acceleration happens before there is much visible forward motion, that the body inertia force is directly in response to that, and that it is purely rearward/parallel to the track surface. He's a LONG way from realizing that the chassis of a rail can intentionally be made flexible for the front wheel droop condition.Mr Robin Parsons said:for inertia to be the effective lifter of the car, the car MUST travel forward, if you have ever watched drag racing you will have observed that dragsters lift their front ends RIGHT FROM THE START LINE, (not enough forward motion for inertia to have worked with the kind of force required) torque from the axle/chassis combination (matches, same as, the ring/pinion example)
He got the gloves a little loose at that point. But he's still a kid relative to some of us, and I hope that he's been paying attention to his own advice. Never mind that he should at least remain open to learning regardless of the source.Mr Robin Parsons said:Oh yes, BTW russ, I learned aout COG's in High school physics classes that occured when I was in grade 10. That was waaaaaaay back when I was ~15/16 years old, or ~1971/72, OOOOOooops that's right, you were not even born yet!
Please, forgive my overt rudeness, (or not, your choice) and beware OLDER MEN (and Women!) as they have had more time to learn more "things".
Except for rearward fluid slosh, rearward compression of the driver's body against the seat, and compression of any seat padding, he's way off base. I could tell him that a microscopic amount of longitudinal chassis compression actually does occur, but that he'd need to know more in order to be able to say whether that effect by itself would increase or decrease the rear tire loading.Mr Robin Parsons said:PS Russ, from the start line, to the finish line, the real, and actual, 'COG' moves towards the rear of the car(!!), without question!
Norm
